-   Learning to Sail (http://www.sailnet.com/forums/learning-sail/)
-   -   Furling Jib (http://www.sailnet.com/forums/learning-sail/98466-furling-jib.html)
scotthardwick 04-13-2013 10:28 AM
Furling Jib
2 Attachment(s)
Greetings to All,
I am trying to install a furling jib on my Oshawa sailboat. I am confuced as to how to install it. I am unable to find a manufacturer on the system, therefore am unable to research it on the net. My question(s); do I completely remove the forestay and replace it with the furling jib? I have included picture of the system perhaps this will help. Thank you in advance for any info regarding this matter.
Scott
Faster 04-13-2013 10:55 AM
Re: Furling Jib
I'm a bit confused by the hank at the top of the sail.. I think the double bale is meant to hook onto the forestay to keep the upper swivel half from spinning, and the drum would tack to the deck a few inches behind the stay.. then you tension the wire luff with the halyard and furl the sail just behind the forestay.
But if you use the hank it won't roll up..... Are there hanks the full length of the sail?
overbored 04-13-2013 12:32 PM
Re: Furling Jib
on a 15' boat I would think you would need to remove the forestay and replace it with the furler and the wire luff in the sail. the fore stay would be in the way for furling unless there is a way to install the furler behind the forestay with some clearance for the drum. the sail luff needs to be tight to furl and the slack forestay would get wrapped up in the sail
scotthardwick 04-13-2013 12:44 PM
Re: Furling Jib
Thanks for the help so far. I have unrolled the jib sail (duh!), there are hanks on the entire length of the sail. Therefore it has to be installed on the forestay? How would one secure it to the mast? I have a regular jib sail, but the furler was thrown in a sail bag. Would like to use it, for the ease, but it is not mandatory. Thanks again for the help.
Scott
overbored 04-13-2013 12:56 PM
Re: Furling Jib
if you use the hanks then they would clip to the forestay and you would hoist the sail with the jib halyard
TQA 04-13-2013 01:33 PM
Re: Furling Jib
You might do better reposting this in gear.
This sort of thing is common but getting it right requires some experience of the particular model. I have to say that the jib hanks are confusing me as the sail appears to have a built in wire luff. On the setups I have used on smaller boats that wire luff would replace the existing forestay. I don't see how you could use the hanks to attach the sail to an existing forestay then use the furler.
Lake Superior Sailor 04-13-2013 01:47 PM
Re: Furling Jib
This is what I use on my Cal it's made by Schafer, Top swivel turn and slides on fore stay drum clips to deck. Hanks are ignored.lift swivel with jib halyard. Or drop roller furler and use hanks on fore stay , as this furler type works poorly in high winds...Dale
scotthardwick 04-13-2013 01:53 PM
Re: Furling Jib
Thanks for the help! Sorry if I posted in the wrong area......its snowing here....and I am trying to sail......
c_witch 04-13-2013 06:14 PM
Re: Furling Jib
1 Attachment(s)
Hi,
I have a barton furler on my boat and its somewhat similar. We kept the forestay. The swivel attaches to the sail and halyard. The drum attaches behind the forestay preferably 3 or 4 inches. I also have hanks on my sail. I found that I had to remove the top hank in order to furl the sail in ANY wind what so ever. Be advised that these furling systems are just that ie the jib is either fully out or fully in. You CANNOT reef the jib with them. Also make sure the halyard is TIGHT'. Heres a photo of our drum sorry about it being blurry.
c_witch
rtawood 04-15-2013 11:42 PM
Re: Furling Jib
Sounds reasonable
