Roller Furling - SailNet Community
post #1 of 8 Old 05-21-2013 Thread Starter
Roller Furling
I tried desperately to upload a photo, but I think the file is too large. I have a Harken roller furling, but not sure which model. No manual. Silver drum with one rope running down the port side into the cockpit.
There is a shackle on top of the drum- I am assuming this is to attach the genoa tack? There is a wire leading out of the top of the drum with a metal "U" shaped piece at the end. Is this some sort of release mechanism??
A sleeve with two plastic holes is located about 3 feet up the track.
The top hole for the genoa halyard shackle?
The other for the genoa head? If so, shackle or tied on?
Lastly, there doesn't appear to be a track to slide the luff into. Do I just pull the halyard up pretty tight, and then winch up the port side line that leads to the cockpit?
Thanks in advance for all of your help!
FirstCandC is offline
post #2 of 8 Old 05-21-2013
jsaronson's Avatar
Re: Roller Furling
Yes
Is it a swivel? If so, yes with shackles.
http://www.harken.com/furling/
jsaronson is offline
The Following User Says Thank You to jsaronson For This Useful Post:
FirstCandC (05-22-2013)
post #3 of 8 Old 05-21-2013
Re: Roller Furling
That's a prefeeder.. you pass the luff tape through the u-shaped piece, then into the slot entry and THEN connect it to the bottom of the swivel.. it (u shaped piece) helps guide the sail into the groove otherwise any folds in the sail can get hung up There must be a slot/groove there, in fact typically there are two grooves but that does depend on the style of furler.
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
post #4 of 8 Old 05-22-2013 Thread Starter
Re: Roller Furling
Ok think I know how to compress the file now.
post #5 of 8 Old 05-22-2013
Re: Roller Furling
Your luff tape slots begin right at that chromed part that your swivel is resting on in the picture. So attach the tack to the shackle on top of the drum, feed the luff (from the head) through the prefeeder, into the slot and then attach the lower shackle on the swivel head. Connect your halyard to the upper shackle on the swivel and hoist away!
post #6 of 8 Old 05-22-2013 Thread Starter
Re: Roller Furling
Tried to do multiple thanks to that post!
GREATEST SITE EVER.
Can't WAIT to launch- Going to do it in style, like Judge Smails:
"It's easy to grin,
when your ship comes in,
and you've got the stock market beat.
But the man worthwhile,
is a man who can smile,
when his shorts are too tight in the seat."
RIP Ted Knight.
post #7 of 8 Old 05-22-2013
Re: Roller Furling
btw... attach your halyard first, and raise the swivel about a foot or two up the foil. Then attach and feed your sail through and up to the swivel. It will go smoother that way.
.. and you're welcome!!
post #8 of 8 Old 05-22-2013
jsaronson's Avatar
Re: Roller Furling
You should join cncphotoalbum.com for C&C specific questions.
Good luck!
roller furling help kananumpua Learning to Sail 14 01-18-2006 04:33 AM
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 08:00 PM
roller furling k8qer Gear & Maintenance 0 01-27-2002 08:27 AM
Roller Furling Dan_T Gear & Maintenance 6 11-02-2001 11:14 AM
Roller furling evecircleM General Discussion (sailing related) 5 10-08-2001 04:54 PM
