Extreme Weatherhelm - Page 2 - SailNet Community
 5Likes
post #11 of 17 Old 05-26-2013
Old as Dirt!
svHyLyte's Avatar
Re: Extreme Weatherhelm
Originally Posted by Racecase View Post
So I been practice sailing with my mainsail only and have has the issue of extreme weatherhelm. To the point where I cant do anything to prevent the boat from turning straight into irons. If I try to fight it, it just drags the rudder. The conditions were 5-15 knot winds, very calm water, the boat is a 25ft fin keel. I tried adjusting the main halyard, outhaul, leech line, traveler position, and mainsheet. Nothing seems to make a difference. Ive done quite a bit of research on sail trimming and have tried to get the correct shape, draft position, etc but I cant find anything to lessen the weatherhelm when going to windward.
Ive read that it could be excessive growth on the bottom (havent been cleaned in a very long time), maybe a blown out sail, maybe I just need to reef.
Any Ideas on what could cause it to be so bad? Im new to sailing but it makes the boat almost unsailable.
Weather helm, or the tendency of the yacht to head into the wind is caused by the center of effort (or pressure) of the sail(s) ("CE") being aft of the center of lateral resistance ("CLR") of the boat in the water (the immersed hull, keel, rudder). A rudder's ability to balance or overcome weather helm is dependent upon the flow of water over the rudder which is itself dependent upon the yacht's speed through the water, the angle of the rudder to the water flow; and, how clean/fair the rudder/hull surface may (or may not) be.
If the boat's bottom is foul, you will not be able to develop much speed which limits the rudder's ability to generate countering force. This loss of ability will be exacerbated if the rudder is also foul as water cannot flow smoothly over the rudder itself. In such circumstances, pulling the tiller further to weather will exacerbate the situation as the flow of the water over the rudder can "stall", in which case the rudder will generate no countering force to weather helm at all but instead, a lot of drag to further slow the boat, making things worse.
To solve the problem, your first task will be to ensure you've got a clean, relatively smooth bottom/rudder. With that done, ensure that you actually do have the sail trimmed properly for the point of sail by ensuring that your tell-tales (which I'm sure you have, yes?) are flying fairly from top to bottom of the sail ("when in doubt, let it out"). In heavier conditions that may require that you ease your traveler to leeward somewhat and harden the vang to take some of the curve out of your leech. And, when sailing do not get too heavy handed with the rudder. You want smooth steady rudder angle changes to prevent stalling flow of water over the blade. Depending upon the size, shape and position of the rudder, you do not want extreme angles. If you feel you are loosing control, you may have stalled the rudder, in which case you'll need to ease off the helm somewhat for a few seconds to allow the flow to reestablish.
If the foregoing does not work, the lead on your CLR vs. CE may be too great, in which case you will need to adjust your masthead forward somewhat and thereby move the CE forward. (One simply eases the back stay and takes up the slack on the forestay.) Approach this incrementally as small changes can have fairly sizable effects.
If none of the foregoing work, it may be that the main is simply too tired and nothing you can do short of recutting, or replacing, the sail will work.
FWIW...
PS: I suggest you pick up a copy of "Sailing for Dummies". You'll find it worth reading.
svHyLyte is offline
post #12 of 17 Old 05-26-2013 Thread Starter
Thank you for all the great info! Im going to have the bottom cleaned and new bottom paint done before I head to the keys in July so that should help. Ill definitely get the jib fixed (its a 110% rolling furler genoa). I understand the need to balance the boat and bring the CE forward, I just didnt think it would be impossible to sail without a jib. (All this weatherhelm comes with no heeling). Ill take a picture of the mainsail, that may help decide if its time to replace.
Racecase is offline
post #13 of 17 Old 05-26-2013
first sailed january 2008
northoceanbeach's Avatar
And it happens no matter which tack you're on?
northoceanbeach is offline
post #14 of 17 Old 05-26-2013 Thread Starter
Yep, port or starboard tack probably within 100 degrees of the wind, either way I get sucked up straight into the wind. Nothing I can do in terms of sail trim or tiller can help it.
Racecase is offline
post #15 of 17 Old 05-26-2013
Yep that's weird. I've sailed main alone in strong wind and had to fight the tiller. Maybe it's just that. Normal but if you are new how do you know what normal feels like right?
post #16 of 17 Old 05-27-2013
It does seen strange that you go into irons with just the main when the wind is up. The only thing I can think of that has not been talked about is; the size of the rudder may be under sized for what you are doing.
Quote: The wind and waver are always on the side of the ablest navigator.-Edward Gibbon, "The Decline and Fall of the Roman Empire"
luck66 is offline
post #17 of 17 Old 05-27-2013
SchockT's Avatar
Mast rake is something else that could be making the weather helm worse. If your mast is raked too far aft, the CE will be even further aft with just the main up.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
Extreme Sailing Action administrator Extreme Sailing Videos 12 06-28-2016 04:44 AM
Extreme Sailing Series 1.6 NewsReader News Feeds 0 03-06-2012 08:00 PM
Ainslie set for Extreme challenge NewsReader News Feeds 0 09-06-2011 11:40 AM
Extreme conditions brokesailor Seamanship & Navigation 8 04-18-2011 08:20 PM
From One Extreme to the Other cb32863 General Discussion (sailing related) 1 04-21-2010 12:36 AM
