Rigging question - What's this for? - Page 2 - SailNet Community
 3Likes
post #11 of 18 Old 05-28-2013 Thread Starter
Re: Rigging question - What's this for?
Originally Posted by deniseO30 View Post
Figures 5-4 through 5-9 give variations of end boom rigging.
here's one
Thank you
pjsmith is offline
post #12 of 18 Old 05-28-2013
AdamLein's Avatar
The only odd thing about the double-ended mainsheet theory is that the sketch in the original post also shows a traditional mainsheet set up on a traveler.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #13 of 18 Old 05-28-2013
FSMike's Avatar
I believe the lines aren't shown all that clearly on the plan.
What can appear to be a single main sheet on the traveler is a part of the double ended system.
What can appear to be a split back stay going to the starboard side is actually the starboard part of the main sheet going to a block, same as the port side.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #14 of 18 Old 05-28-2013 Thread Starter
Yes, and that's what I use now. Maybe it just came equipped for both.
pjsmith is offline
post #15 of 18 Old 05-28-2013
flo617's Avatar
Is it a double block on the traveler? Maybe there are two lines, each of them symmetrical and attached to the boom through the block. Adjusting the tension on both lines would allow control of the sheeting angle and traveler position. That notion would be supported by the fact that the traveler does not seem to have any way to lock the car.
Although I can see problems from that system due to the fact that the both lines need to be attended to to sheet out.
flo617 is offline
post #16 of 18 Old 05-29-2013
Barquito
Barquito's Avatar
I think the block is for the spinnaker sheet. The diagram just shows how it can be used to secure the boom when the sails are down.
Valiant 32
Barquito is offline
post #17 of 18 Old 05-29-2013
This may help. I have other set ups, from the end of the boom.
sony2000 is offline
post #18 of 18 Old 05-29-2013
On my boat the blocks could be used for turning the topsail yard braces. This may not be applicable to your vessel.
FSMike likes this.
Capt Len is online now
Rigging question Sublime General Discussion (sailing related) 4 02-21-2012 07:14 PM
Rigging question Sublime General Discussion (sailing related) 3 12-30-2010 07:25 PM
rigging question sailingtime Gear & Maintenance 6 10-18-2010 11:35 AM
Question about my rigging l0keman Gear & Maintenance 26 05-02-2007 03:48 PM
rigging question drlizard Gear & Maintenance 7 02-22-2006 11:28 AM
