stays and shrouds too loose? - Page 2 - SailNet Community
post #11 of 16 Old 05-28-2013
paulk's Avatar
Re: stays and shrouds too loose?
The general idea is that you don't want your mast moving around a lot when you tack, and you want the mast to be evenly centered on the boat: straight up, as far as port/starboard goes. If the leeward shrouds are really loose, the mast will be swaying around in mid-tack. Not only is this slow, with the mast's weight wobbling around, but it probably puts additional cycles on the standing rigging, tending to wear it out faster. If the leeward shrouds are loose it also means the mast isn't centered. On a keel-stepped mast, this puts a side-strain at the partners, where the mast goes through the deck or cabin top. This can cause damage and leaks. Loose shrouds also mean that the mast is actually falling off to leeward on whatever tack you're on. This is really inefficient going upwind: you want the airfoil (your sail) to be as close to right angles to the wind (straight up) as possible. If your mast is falling off 10º when you're sailing the boat with the hull flat, your competition with the mast straight up will be pointing higher than you. If you heel 10º, your mast is 20º off vertical: much slower than it could be. Instead of solely working to push the boat forward, a component of the sail's lift is actually pulling the mast down towards the water, making you heel more! Keeping everything snug, even the leeward shrouds, is probably a good idea even if you're not racing.
paulk is offline
The Following User Says Thank You to paulk For This Useful Post:
Lateen Luffer (06-02-2013)
post #12 of 16 Old 09-06-2013
Alex,
Thank you for the book recommendation. I just ordered and cannot wait to read it.
I will offer a "new boater" review once I have a chance to read.
Best regards,
Dan
Dan Diego is offline
post #13 of 16 Old 09-06-2013
Dog Ship's Avatar
I have about 1000 lbs. on my lower shrouds, maybe a bit more on the uppers at the dock. In 15 knots of wind, close hauled, the leeward shrouds are unloaded but not loose.
Check out the tension on other boats of similar size and rig configuration to yours and you will get a good feel for it eventually.
A Loos gauge is not very accurate and for the number of times you will use one they are way over priced for what they are.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #14 of 16 Old 09-06-2013
4KSB driver.
Your sail manufacturer should be able to give you "rig tune" guidelines for your boat.
That includes recommended rake.
As for tension... some can give you Loos gauge numbers, some will give you a way to tell what tension you need.
But YES, under sail, mast otherwise in column and also straight throughout, if a leeward shroud is flopping in a moderate breeze, you are too loose.
MOST tuning guides will tell you how to "dock tune" for your coarse setting... but then tell you to sail a close hauled starboard tack, adjust the leeward shrouds to "x", then tack and do the same adjustment to the other side. Mostly because it's easier to add another crank on the shroud when its got less pressure on it.
Hadn't thought of the middle of the mast dropping if your leeward lowers were loose when you're on the wind, but it makes perfect sense. But then I could see in light air where that might be "advantageous" too.
And RIG tune isn't my forte' but I've recently understood why I should get better at it!
***Boatless
**** Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #15 of 16 Old 09-06-2013
Sailboat owners should "invest" in a Loos tension gauge, much like a vehicle owner should invest in a tire pressure gauge. The manufacturers or owners groups usually have specs available; or use a setting of 10% of breaking strength as a guideline. The only way to determine the tension setting is with a gauge of some type.
Seaduction is offline
post #16 of 16 Old 09-07-2013
manatee's Avatar
Adjusting Your Rig
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you don’t."
~~Dylan Winter,
manatee is offline
shrouds and stays dbellet Gear & Maintenance 2 06-25-2012 12:25 PM
galvanize shrouds/stays PeterSailer General Discussion (sailing related) 3 04-28-2011 03:12 PM
Which shrouds/stays get replaced first? northoceanbeach Gear & Maintenance 15 03-30-2010 09:08 PM
Do stays/shrouds make good FM radio antennas? dman535 Gear & Maintenance 4 07-09-2009 09:38 PM
Tuning Shrouds and Stays Kestrel303 Gear & Maintenance 2 06-22-2009 10:14 AM
