Tankless Water Heater, CNG? - Page 2 - SailNet Community
 2Likes
post #11 of 26 Old 06-12-2013
Maine Sail's Avatar
Re: Tankless Water Heater, CNG?
Originally Posted by deniseO30 View Post
Well I did a bit of looking up. It seems there are a number of tankless units that meet ABYC guidelines. CNG and LPG are very differen't but the safety guides are not very differen't.
where will you make "another hole in your boat" ? for the vent?
There are a lot of sleazy companies that lie and say they are made for use on boats when in-fact they do not meet the minimum ABYC safety requirements..
I don't know of a tankless propane or CNG heater that actually meets the ABYC standard. Unfortunately there are plenty of companies willing to market these tanks to boaters knowing darn well they don't meet the minimum safety requirements..
Please be aware that some companies like Ex--l are purposely misleading customers. No "vent free" water heater meets the minimum safety standards for installation on boats in the USA under ABYC, NFPA 302 or NMMA. No exhaust vent only heater meets the minimum safety standards.
ABYC:
26.5.10 Unattended appliances shall incorporate a room sealed combustion system.
ABYC Definitions:
Definitions:
Unattended Appliance - appliances intended to function without frequent attention by an operator, and that may cycle on and off automatically, such as refrigerators, thermostatically controlled cabin heaters, and water heaters.
Room Sealed Combustion System - a combustion system in which incoming air, the combustion chamber, and the outgoing products of combustion are sealed from the boat interior.
This means that the unit must be vented and also must take combustion air from outside the boat in a sealed combustion manner, meaning exhaust vents out side the vessel and intake air also comes from out side the vessel. Usually a dual wall vent pipe is used with make up air coming in around the out side of the inner vent pipe to also help keep it cool though some appliances use a two vent system..
A water heater meets the ABYC definition of an "unattended appliance" a galley stove is an "attended appliance".
Just because a manufacturer makes lofty "claims" it does not mean they are legitimate claims or in the slightest bit true if you want to do things to current and accepted safety standards or to have a vessel that could pass an insurance survey.
The Ex--l or any other "vent free" water heaters do not meet these requirements.. Use at your own risk and please check with your insurer before installing one..
I have had to remove a "vent free" water heater that failed to pass an insurance survey.
If a surveyor in the USA passes a boat with a "vent free water heater" they are simply a poor surveyor and simply not doing their job.
One owner who called me with a fairly new vent free water heater was extremely PISSED OFF that they bought a product that purposely mislead them because their surveyor flagged it is an unsafe heater.....
When shopping for a LPG tankless water heater it is buyer beware and please be careful...
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
olddog60 (06-13-2013)
post #12 of 26 Old 06-12-2013
One of None
deniseO30's Avatar
Why I said "it seems"
And I did not suggest he buy any
My last project!
deniseO30 is offline
post #13 of 26 Old 06-12-2013
Maine Sail's Avatar
And these days with sooooo many sleazy companies things are not always what they "seem"...
______
post #14 of 26 Old 06-12-2013
One of None
deniseO30's Avatar
Yall think this scary? You should read some of the threads on the wooden boat forum!
Burn wood in your wooden boat while storing wood to burn on the wooden boat but don't burn the wood that the wooden boat is made of
elspru and mad_machine like this.
My last project!
post #15 of 26 Old 06-12-2013
Old enough to know better
Now I don't want to be spreading miss information, but I contacted Precision Temp about the ShowerMate M-550. I specifically asked if it was ABYC approved and they said yes it is. He did not provide any documentation at all though. I do know they are not legal at all in Canada on boats.
Another option would be a hydronic heater and they offer a heat loop for the hot water but they run on diesel. It is kind of pricey.
miatapaul is offline
post #16 of 26 Old 06-13-2013
Maine Sail's Avatar
The last time I looked into a Precision Temp they were not "sealed combustion". In order to meet ABYC standards they must be sealed combustion.
Perhaps they've added one to the line up but the web site does not show it... As far as I know these are exhaust only to exterior of vessel not exhaust & intake to/from exterior....
This is what the manual for the Showermate M-550 "marine" unit says..
"At least 20 square inches of incoming air is necessary and the power vent of the unit should always be vented to the outside with 2” approved duct."
That is not sealed combustion. The ABYC standards are not difficult to read or understand but apparently PT missed the part about it needing to be sealed combustion for use on boats...
______
post #17 of 26 Old 06-15-2013
if the portable shower ones support electric they may be compliant as they don't have any exhaust when operating in electric mode, though admittedly it is 11KW or 100amp.
Alternatively there is also the Soviet shower method -- how people took hot showers in the soviet-union and post-states where hot-water is either intermittent or completely absent. I remember it from my childhood.
The method is to have a bucket or some container which holds liquids, fill it mostly with cold water, then set the kettle to boil, pour in boiling water, stir and test is appropriate warmth (exact proportions of hot-to-cold depend on water temperature), then use a measuring cup or some such to pour it over yourself in the shower.
Washing dishes is same deal, make sure either container wide enough, or dishes small enough to fit.
I was thinking that if you happen to have a gravity-fed solar-shower assembly, then in winter or relatively cold times, can simply top it off with some kettle water. Though admittedly solar-showers and gravity-fed ones do have "tanks". Could even consider a bucket to be a "tank", though bucket very handy item, since can also use it for laundry, and many other uses.
Of course there is also the option to take cold showers, which are supposed to be good for you. In Russia snow bathing is one (fun) way to get clean during the winter. Winter swimming is also great fun :-), good for circulation, and heat-generating ability (assuming you have enough dietary-iodine).
elspru is offline
post #18 of 26 Old 09-01-2013
I'm looking for help. I had one on my old boat for eight years and loved it.
I just got a used Wolter that was never installed. I tested it and it is working fine. It has a flue hood with the 3" vent.
I'm looking for a manual and I found part of one online, but it was missing some pages. One thing in particular I'm trying to figure out is how the optional flue fan was connected and what type of fan it was. I had put the fan option into my Wolter on my last boat. I liked the power venting as it assure proper flueing. It looked like just a normal muffin fan and I remember hooking it up to the terminal strip, just not exactly where.
Would anyone have any information, like a manual or information on the fan connection or type, like CFM for the flue vent option?
Please e mail me tcdunlap(at)gmail.com
Thanks,
Tim
tcdunlap is offline
post #19 of 26 Old 09-01-2013
Oh, as far as being "compliant, last I checked ABYC is a voluntary standard that is mainly forced onto boat owners through problems with surveys, and subsequently insurance companies that will not insure your boat. I'm not saying we should not have some standards, but from my 35 years of boating experience, it is a rare builder that builds boats that meet all ABYC standards. Then there are problems with the standards differing from those in Europe, something else to be aware of.
Surveyors do sometimes misinterpret rules, and this has resulted in people, myself included, in having to modify boats to get insurance. Meanwhile they miss things all over the place. I was just aboard a boat that had the fuel tank vented in the bilges (diesel), and batteries installed in the bilge on their side, and not well fastened down. The survey did not even mention these things.
As far as gas water heating, if done right, I think it is very safe. With systems that have vents, I don't see a problem; I do like power venting ones best, as they assure proper draft. I would not use an unvented heater, but I think some unvented ones can be modified to have vents. I know some boater have done so.
The few instances of problems, and some were quite serious and involved deaths, were the result of people not following installation instructions or common sense. One happened near where I live. The person involved had installed the flash water heater in the head shower without a vent. This was a live aboard situation, and the person used it in the winter, with the hatches close up, with disastrous consequences. You can hardly fault the equipment for the result.
I don't like to see these heaters mounted in living spaces. A cockpit locker would be a better choice. If you have the room and are really concerned, I think you could make any one of these heaters ABYC complaint by building a gas tight locker to put it in. Supply outside air and a flue and you have it. Maybe this is more than most people are capable of, but it's not impossible. The Precision Temp would be ideal for this, as it is power vented. If done this way, you are not taking combustion air from inside the boat. I think the Precision Temp is plenty safe even if using inside air for combustion.
I would also argue that a flash water heater is an attended appliance. It is not left on when no one is on board. Even if power was left on to it, it should not cycle on. I don't see any reason for it to be on except when one is right there using it. In this regard it is no different than a galley stove.
You ought to have a smoke and carbon dioxide detector on your boat too. Common sense, but I don't think this is required by ABYC.
All-in-all, even with all the modern convinces being added to boats, boating has never been safer. Very few people are injured or die from this activity. The number of deaths has fallen over the years. Remarkable when you think of things like Jet Skis showing up on the water with hundreds of horsepower. Your chances of becoming a statistic are much greater in a boat with no motor and less than 16 feet. More people die falling on their front steps than boating. I'm growing tired of all the "safety police" trying to tell me how to conduct my business. No activity is without risk, but people will jump in a car and think nothing of it, while people are flying past them driving with less thought than they use brushing their teeth!
Anyway, I say these units can be installed in a safe and effective way. The risk can be mitigated. They are no worse than the galley stove. When gas stoves fist started showing up on boat, many people said they were unsafe. It turned out insurance company clams fell, as compare to older technologies like fuel oil or alcohol stoves. Suddenly they were no problem.
Does it take some thought and careful planning, sure, but I think they are a great idea for increased comfort. I used one everyday for over eight years living aboard without a problem of any sort. Make up your own mind; I'm just a guy with an engineering background, and a licensed 100T CG captain with thousands of hours on the water. What do I know?
Cheers,
Tim
tcdunlap is offline
post #20 of 26 Old 09-07-2013
How about propane heated camping showers? A company called Zodi makes some that are small and could fit neatly into a boat. Granted they aren't made specifically for sailboats, but I'm sure it could be MacGyvered in
SailorBrett is offline
Tags
cng users
Eemax "marine/rv" Tankless Water Heater - EX2412M and insuarnce? SanDiegoChip Gear & Maintenance 11 06-23-2016 11:51 PM
Need to replace dead Wolter tankless water heater Moxieskipper General Discussion (sailing related) 11 09-01-2013 02:04 PM
Charley Noble, tankless water heater vent canucksailorguy Gear & Maintenance 16 05-16-2012 06:43 PM
tankless water heater waterwks4me General Discussion (sailing related) 8 06-27-2011 07:43 PM
Tankless Water Heaters Pub911 Gear & Maintenance 14 01-21-2008 11:42 PM
