Tankless Water Heater, CNG? - Page 3 - SailNet Community
 2Likes
post #21 of 26 Old 09-07-2013
Old enough to know better
Re: Tankless Water Heater, CNG?
Originally Posted by SailorBrett View Post
How about propane heated camping showers? A company called Zodi makes some that are small and could fit neatly into a boat. Granted they aren't made specifically for sailboats, but I'm sure it could be MacGyvered in
Well there was often explosions on.MacGyver so I am sure it is not a good idea!
Sent from my ADR6425LVW using Tapatalk 4
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #22 of 26 Old 09-07-2013
Dirt Free
boatpoker's Avatar
Originally Posted by miatapaul View Post
Now I don't want to be spreading miss information, but I contacted Precision Temp about the ShowerMate M-550. I specifically asked if it was ABYC approved and they said yes it is. He did not provide any documentation at all though. I do know they are not legal at all in Canada on boats.
Another option would be a hydronic heater and they offer a heat loop for the hot water but they run on diesel. It is kind of pricey.
Either the company is unethical or ignorant ! ABYC do not "Approve" anything at all, they merely set a standard.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #23 of 26 Old 09-07-2013
Causing a propane tank to explode is a tremendously difficult undertaking. You can drop them, hit them with a car, sometimes even shoot them and still an explosion won't happen. They're a safe energy source as long as you aren't placing the bottle directly inside the fire.
SailorBrett is offline
post #24 of 26 Old 09-07-2013
Dirt Free
boatpoker's Avatar
I don't believe anyone expressed concerns about the tanks.
Oxygen depletion, carbon monoxide poisoning and propane leaks should be the concerns
post #25 of 26 Old 09-07-2013
True, and you'll have to worry about ventilation with most hot water systems, including a propane system. They're mostly used outdoors anyway. Just take your shower in the summer with some jury rigged curtains and you'll be fine.
post #26 of 26 Old 09-07-2013
remetau's Avatar
We have been using our vent-less Excel for 5 years without any problems. We have a dedicated LPG system for it along with a water solenoid that opens the supply to it when the LPG solenoid opens. This keeps the system from trying to ignite when the water is on, but the gas is not.
Don & Diana
sv Re Metau an HC33t
remetau is offline
Tags
cng users
Eemax "marine/rv" Tankless Water Heater - EX2412M and insuarnce? SanDiegoChip Gear & Maintenance 11 06-23-2016 10:51 PM
Need to replace dead Wolter tankless water heater Moxieskipper General Discussion (sailing related) 11 09-01-2013 01:04 PM
Charley Noble, tankless water heater vent canucksailorguy Gear & Maintenance 16 05-16-2012 05:43 PM
tankless water heater waterwks4me General Discussion (sailing related) 8 06-27-2011 06:43 PM
Tankless Water Heaters Pub911 Gear & Maintenance 14 01-21-2008 10:42 PM
