Liveaboard Sail upkeep - Page 2 - SailNet Community
post #11 of 13 Old 12-21-2013
Re: Liveaboard Sail upkeep
Sunbrella manufacturer recommends Woolite only as a cleaning agent.
Personally, I think if you're essentially 'welded' to the dock anyway your sails will thank you for taking them down and storing them in a dry area.. as you're living aboard, off the boat somewhere not too far away would be best. Even the main under the cover would be better off stored properly, and if you're using any kind of tarp you'll wear the sail cover out with chafe if it's left on the boom.
Do you have a storage locker in your marina? Once everything is cleaned and stitched up that'd be the place for them for now.
Faster is offline
post #12 of 13 Old 12-21-2013
CaptainForce's Avatar
Dirt and mold can be problems, but to two factors that present the greatest risks to your sails are chafe and UV damage. For chafe prevention make sure that your sails on the boom are tied with straps around the sails only and not with straps around the sail and boom. A tuck of sail that is tied between the wrap line and the boom can chafe away with the constant rock at the dock. The lines holding the sail cover would normally be around the boom, but once again, there should not be a fold of sail left between these straps and the boom. For the UV protection just be sure that the whole sail is covered, particularly without the clew sticking out aft.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #13 of 13 Old 02-16-2014
good info
olysux is offline
Proper Sail Upkeep jcase12 Gear & Maintenance 14 01-30-2013 12:05 AM
Need advice on cost of ownership and upkeep Soundtrackzz Boat Review and Purchase Forum 10 05-21-2012 02:05 PM
shared ownership- trade equity for upkeep and fees? hertfordnc General Discussion (sailing related) 10 12-11-2009 11:19 PM
Inflatable plywood upkeep.. TommyD Gear & Maintenance 3 11-24-2009 08:31 AM
looking for a liveaboard WindRider68 Boat Review and Purchase Forum 11 11-17-2007 08:38 AM
