Extreme Cold - Page 10 - SailNet Community
 17Likes
post #91 of 110 Old 02-05-2014
pdqaltair's Avatar
Re: Extreme Cold
Originally Posted by miatapaul View Post
They are not allowed to manufacture them anymore but there are a few years worth in the pipeline. I think though that a incandescent light bulb is way to fragile and short lived for me to use as a source of heat to keep a seacock warm, a golden rod type of heating element would be more reliable. Though we did once use them for heat in an outdoor cat's house during the winter. I don't think she (the cat) cared much if it worked or not, but the snow sure melted off the top of it.
Winterizing it just makes more sense, along with keeping cabinet doors in front of them open to keep warm air circulating around them.
I beilve decorative bulb and special purpose bulbs (CF and LED won't work in the oven or fridge) are exempt.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #92 of 110 Old 02-05-2014
Re: Extreme Cold
Originally Posted by Delta-T View Post
These are outlawed for closet use because of fires.
Closet Lights – New Rules for Closet Lights
"Surface-mounted or recessed fixtures are both permitted, but exposed (uncovered) light bulbs are not. "
Has anyone ever had a hot bulb get wet? I have and they shatter before the element sparks/burns out. All it would take is one drop of condensation and some combustible bilge fumes.
Good references DeltaT. I never said the things people do are right, or safe, and your post reinforces that.
I personally saw an Islander 36 explode about 400 feet from me once. Not a pretty sight as the entire deck & coach house blew clear off the boat.
lightfoot is offline
post #93 of 110 Old 02-05-2014
Re: Extreme Cold
Hi wattage, low wattage, specialty, halogen, many types of filament bulbs are still available and being manufactured.
But if you want to keep something warm, look for "heat tape" in the plumbing section. Or for infrared heat lamps (typically reflector spot type) in the store. The heat tape is designed to keep pipes from freezing up and there's no filament to burn out.
Incandescent bulbs are (were) cheap and convenient, but there are better ways to generate heat.
hellosailor is offline
post #94 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
+1 on the heat tape being safe. I bought one not to long ago and it had a GFI on the plug.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #95 of 110 Old 02-05-2014 Thread Starter
Re: Extreme Cold
Question on the Heat Tape:
How much heat can they take without burning up or becoming ruined.
I'm asking because I'm curious if heat tape can be wrapped around engine parts as well as through hulls.
Pearson796 is offline
post #96 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
It can be used on engine piping, manufacture says up to 1-1/2" pipe. I would take that to mean with the low heat output, the heat will not penetrate very far. I would use armiflex insulation over heat tape wires and item being heated. http://www.emersonindustrial.com/en-...csheet_web.pdfhttps://www.youtube.com/watch?v=tZm1v12oJJM
"How much heat can they take without burning up or becoming ruined."
Sorry I do not understand this question? How much heat can what take?
Sorry, I was mistaken that the heat tape I purchased has a GFI plug. It does not, but the heat tape does need to be plugged into a grounded GFI circuit.
Eric
Delta-T
Delta-T is offline
post #97 of 110 Old 02-05-2014 Thread Starter
Re: Extreme Cold
The heat tape... Can you wrap the heat tape around areas of the Engine that reach high temps.
post #98 of 110 Old 02-05-2014
Re: Extreme Cold
Engine parts can reach extremely high temperatures, well above 100C on the exhaust manifold, and heat tape is not designed for anything near that. You'd have to contact the individual manufacturer to find out how much heat any product can withstand, but I wouldn't pout them on anything that you couldn't lay your palm on.
post #99 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
Like the exhaust? And leave the heat tape on when running the engine? I would say it depends on the type of heat tape and if you can hold onto the item with your hand with the engine running, it will be fine.
Are you talking about your heat exchanger that froze on you? Yes, on that would work great!
Pearson796 likes this.
Eric
Delta-T
Delta-T is offline
post #100 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
100C is not a problem for heat tape. Heat tape, depending on the type, working temps. ranges from 150 to 450 F and the jacket will do twice that. This can be an issue with plastic pipes. My wet exhaust hose is rated for 250 F.
Eric
Delta-T
Delta-T is offline
Extreme Yachts! extremeyachts General Discussion (sailing related) 2 11-05-2013 06:54 PM
Extreme Weatherhelm Racecase Learning to Sail 16 05-27-2013 11:55 PM
Extreme conditions brokesailor Seamanship & Navigation 8 04-18-2011 08:20 PM
From One Extreme to the Other cb32863 General Discussion (sailing related) 1 04-21-2010 12:36 AM
Dealing with Extreme Weather Michael Carr Seamanship Articles 0 07-31-2003 08:00 PM
