Extreme Cold - Page 11 - SailNet Community
 17Likes
post #101 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
A little something on the different types...Heat Tape
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #102 of 110 Old 02-05-2014
Re: Extreme Cold
Originally Posted by hellosailor View Post
Hi wattage, low wattage, specialty, halogen, many types of filament bulbs are still available and being manufactured.
But if you want to keep something warm, look for "heat tape" in the plumbing section. Or for infrared heat lamps (typically reflector spot type) in the store. The heat tape is designed to keep pipes from freezing up and there's no filament to burn out.
Incandescent bulbs are (were) cheap and convenient, but there are better ways to generate heat.
The problem with "HEAT TAPE" is that they are normally at least 6 feet long, and you only need about 3-6 INCHES of the stuff to adequately warm up a typical thur hull fitting.
Pearson796 likes this.
lightfoot is offline
post #103 of 110 Old 02-05-2014 Thread Starter
Re: Extreme Cold
That's good information. Unfortunately, where I want to put it, it would be very difficult to insulate the area so the heat tape works effectively.
Pearson796 is offline
post #104 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
"Non regulating heating cable: This type of heat tape is regulated by a thermostat. It can be purchased by the foot or in a roll as well. The heating cable can be custom fit to your application because it can be cut to any size that is needed and the ends are then added to the length of cable. This type of heat tape will require a connection kit with an end plug and outlet as well as a thermostat to regulate the temperature."
Eric
Delta-T
Delta-T is offline
post #105 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
The lack of space is an insulator. You might need to use more wraps of tape around more times for more concentrated heat. I believe covering with insulation is best, but not a requirement.
Eric
Delta-T
Delta-T is offline
post #106 of 110 Old 02-05-2014
Re: Extreme Cold
OK, Mr Pearson, several of us have been trying to give you the "HINT".
Since you haven't taken it, here is the BLAST.
BOATS ARE NOT DESIGNED TO BE LIVED ABOARD, IN FREEZING TEMPS. PERIOD!
IF YOU'RE BENT ON KILLING YOURSELF, OR SINKING YOUR BOAT, YOUR CALL!
There's good reason that almost 100% of boat owners would never attempt what you're attempting.
Learn from others. Don't attempt to re-invent the wheel, especially since you don't appear to even understand what that "WHEEL" actually is.
I'm done with you.
Good Luck,
Sorry
post #107 of 110 Old 02-05-2014
TakeFive's Avatar
Re: Extreme Cold
I'm done with you.
Good Luck,
Sorry
Chill out, dude. Lots of people live aboard in freezing temps.
Rick S., Swarthmore, PA
TakeFive is offline
post #108 of 110 Old 02-05-2014
Delta-T's Avatar
Re: Extreme Cold
Well isn't that special! https://www.youtube.com/watch?v=bLw4fcKFTtY
Eric
Delta-T
Delta-T is offline
post #109 of 110 Old 02-05-2014
Re: Extreme Cold
"The problem with "HEAT TAPE" is that " So, you treat it the same way any sailor treats any line. You never CUT a line, you just shorten up, coil it, wrap it...You take the six foot heat tape and wrap it around the fitting, or coil it up and hang it so the extra heat is there, and then tuck some bubblewrap over it to concentrate all the heat on that part.
The heat tape should self-regulate temperature so "too much" isn't a problem. In the worse case it warms up the rest of the boat.
I just had a mini-reflector (damned expensive tungsten bulb) burn out in less than 200 hours of use, when it was rated for 2500 hours. Would I trust a light bulb to keep anything from freezing? Don't think so. Yes, sailors have for ages. And you just won't hear about the ones who returned to find frozen engines blocks. That why there are block heaters, heated dipsticks, electric engine blankets, and other devices. A whole range of them. That don't burn out like light bulbs.
A light bulb is just the wrong tool for the job.
hellosailor is offline
post #110 of 110 Old 02-07-2014
n2ubn's Avatar
Re: Extreme Cold
I use a stainless steel Refleks model 66MK boat heater. It has kept my Bombay Clipper 31 toasty warm (even in the recent near 0 deg temps) during the winter months of New Jersey for over 35 years of living aboard. It burns diesel fuel and is available from Hamilton Marine, Searsport Maine.
Captain Ron
Lou452 likes this.
Ron Pearce
Callsign: n2ubn
Web Site: captainron.org
n2ubn is offline
Extreme Yachts! extremeyachts General Discussion (sailing related) 2 11-05-2013 06:54 PM
Extreme Weatherhelm Racecase Learning to Sail 16 05-27-2013 11:55 PM
Extreme conditions brokesailor Seamanship & Navigation 8 04-18-2011 08:20 PM
From One Extreme to the Other cb32863 General Discussion (sailing related) 1 04-21-2010 12:36 AM
Dealing with Extreme Weather Michael Carr Seamanship Articles 0 07-31-2003 08:00 PM
