Extreme Cold - Page 8 - SailNet Community
 17Likes
post #71 of 110 Old 02-02-2014
Re: Extreme Cold
Originally Posted by Lou452 View Post
I have never had to use a wooden plug on a thru hull fitting. I am adding these tales for some insight on wooden plugs or the use of them. Does any one else have thoughts or tales ?
A man would need to use great care if you are below the water line and trying to drive a plug in. NO BOAT IS WORTH A LIFE. if you are miles from land risk factors change. The loss of the boat might be a huge loss and change the odds of making it. If you are at the dock the game is all about you. Maybe the dock lines would hold her up?
I can tell you as a pipefitter I have used a wooden plug to stop a 2" inch opening off an 8" pipe with glycol/water mix at about 40 psi the nipple was broken fitting off by a fork truck. The factory needed to run until shift change a cut and weld could be made.
The plug was drove into the hole with the pumps off. With the pumps off their was very little head pressure. I was expecting it to shoot out like a cannon and the mess to spread but it held.
I have changed a 3/4" inch thermal well at the basement three floors down on a 6" condenser water pipe. This was beyond wet No garden hose has that kind of pressure. It was chilling. I am still amazed that I was able to thread in a new one. If I failed on that one It would have cost a day or so but everyone new the risk. I would not have used a plug We had made the decision to open the main drain If I failed. Picked the day and did it.
If you had to have a reaction on a boat . I am not sure you would have time even if the plug was on a string next to the opening with a hammer at the ready.
Good day, Lou
And what kind of water pressure do you expect from a broken seacock 18 inches below sea level?
Have a look at these two videos..
Lou452 likes this.
knuterikt is offline
The Following User Says Thank You to knuterikt For This Useful Post:
Lou452 (02-02-2014)
post #72 of 110 Old 02-02-2014
sunfish?junior?
Re: Extreme Cold
I was expecting a lot more water at a faster speed ! Thanks for that post.
Good day, Lou
Lou452 is offline
post #73 of 110 Old 02-02-2014
Re: Extreme Cold
Sprayed closed cell anti microbial insulation foam works. But shaving it to "size/fit" is a b,,, Yet worth it! it comes in two five gallon pressurized tanks!
I always sailed in the winter if the ice did not preclude me. Have woke up many times in ice,,,no problems, winch in your anchor through the inch of ice! As you motor forwards,,then back out till you reach, the inlet. Li/NY
OH! HUGE THING! VENTILATION IS B> I USE AGA Mask.
JoeBotz is offline
post #74 of 110 Old 02-02-2014
Re: Extreme Cold
Originally Posted by Pearson796 View Post
You have people living year round on boats on the Great Lakes? I'm from the Detroit area originally and I don't remember seeing boats still in the water in the winter.
We've bubbled boats for as long as I can remember. At least 40 years here on Lk St Clair.
I'm talking about a few hearty souls who are actually living aboard a few of these bubbled boats. Go figure ?
lightfoot is offline
post #75 of 110 Old 02-03-2014 Thread Starter
Re: Extreme Cold
Yachting Monthly's Crash Test Boat is holed Part 1 - YouTube
Yachting Monthly's Crash Test Boat is holed Part 2 - YouTube
Oddly enough, I just watched this one a few weeks ago and then watched the one where they turtled a boat to see who much stuff flew around inside.
Pearson796 is offline
post #76 of 110 Old 02-03-2014 Thread Starter
Re: Extreme Cold
All I can say is.. Wow, that's hardcore.
post #77 of 110 Old 02-03-2014
Re: Extreme Cold
I can see one minor drawback to H2Out marine products:
"How to regenerate your H2Out Dehumidifier:
Simply place the unit in an oven* for two-three hours at 300F (149C). - See more at: http://h2out.com/faqs#sthash.tawcp1wL.dpuf"
So who is going to run the oven on their boat for 3 hours every day? In order to...drive the moisture out of the H2Out and back into the cabin of the boat?
Just seems like an electric heater (goldenrod) or ventilated heater (external combustion) is a way more effective way to go.
hellosailor is offline
post #78 of 110 Old 02-03-2014 Thread Starter
Re: Extreme Cold
Apparently we had an ice storm last night. It was raining a good bit in the afternoon and all of a sudden the temps dropped and left a thick layer of ice on everything.
We have over an inch of ice in places on the boat. The expected temps in the next few days, aren't going to be enough to melt the ice I don't think.
We chiseled the ice off our vehicle and attempted the snow/ice covered hill out of the slip parking. I barely made it up the hill and as steep and narrow as that drive is, I would not attempt to come back down it.
As for the boat, I wish the weather man had been able to predict this so I could have covered the cockpit of the boat. The hatch was frozen shut this morning and it took a bit of work to get out.
post #79 of 110 Old 02-03-2014
Minnesail's Avatar
Re: Extreme Cold
There's even a live aboard community here in Minneapolis, on the Mississippi river. Houseboats, not sailboats, but yeah all year long. And it is *cold* here.
Pearson796 likes this.
Catalina 22
on a starboard tack
Minnesail is online now
post #80 of 110 Old 02-03-2014
Re: Extreme Cold
When I was living aboard (Toronto winters). Some people would hang a 60 watt bulb and fixture next to each through hull to keep then nice and warm over the winter! I did this for a couple of winters and then realized that this technique wasn't necessary with the bubblers in our marina! The system they used had massive compressors and the entire slip would stay ice free.
pcmm is offline
Extreme Yachts! extremeyachts General Discussion (sailing related) 2 11-05-2013 06:54 PM
Extreme Weatherhelm Racecase Learning to Sail 16 05-27-2013 11:55 PM
Extreme conditions brokesailor Seamanship & Navigation 8 04-18-2011 08:20 PM
From One Extreme to the Other cb32863 General Discussion (sailing related) 1 04-21-2010 12:36 AM
Dealing with Extreme Weather Michael Carr Seamanship Articles 0 07-31-2003 08:00 PM
