WiFi on the Boat? - Page 3 - SailNet Community
 9Likes
post #21 of 43 Old 12-27-2009
Triquetra's Avatar
Wireless cards for WIFI
I actually had a Verizon PCMCIA card that allowed the Admiral to surf the web at about 5 nm off of Daytona. I recently upgraded to the MIFI router, so that I can connect both my laptop and hers at the same time, and it also worked off the coast at about the same distance. They may vary in speed, but if you are boating and can get a cell phone signal, it may be worth considering. Since I live aboard, it was the best solution for me.
Triquetra is offline
post #22 of 43 Old 12-30-2009
Send a message via Yahoo to bexaminer
I would suggest a USB modem. That should solve your problem.
bexaminer is offline
post #23 of 43 Old 01-16-2010
bellefonte's Avatar
if money is not a problem...
I found some systems when lookin for my RV applications.
SWE-DISH and world leading stabilized platform developer Saab systems have joined forces in developing a high performance SATCOM on-the-move terminal (four-axis antenna system) that enables broadband satellite communications with land vehicles and marine vessels while moving at top speed.
Contact Details
SWE-DISH Satellite Systems AB
P.O. Box 6075, Torggatan 15
171 06 SOLNA
Sweden
Tel: +46 8 728 50 00
Tel: US Phone: +1 703 476 1826
Fax: +46 8 728 50 50
Fax: US Fax: +1 703 476 5423
Email: sales@swe-dish.se
Email: us-sales@swe-dish.com
URL: SWE-DISH » SWE-DISH SATELLITE SYSTEMS - Satellite communications products and services
bellefonte is offline
post #24 of 43 Old 01-16-2010
I'd point out the post I wrote on my blog regarding WiFi solutions for Cruising sailboats.
slax likes this.
sailingdog is offline
post #25 of 43 Old 01-17-2010
bellefonte's Avatar
internet anywhere
These suggestions seem to be all about connecting to a land based internet service of some sort.
What about satellite services so that you could ping it from the middle of the
pacific ocean?
Anyone?
post #26 of 43 Old 01-18-2010
Unless you have essentially an unlimited budget and a boat large enough to have very reliable electrical power and a very large battery bank, using satellite-based internet is not a great idea.
The satellite-based internet connections require a gyro-stabilized antenna to work properly. On a small sailboat....and small means anything up to 100' or so...the power draw of the gyro-stabilized dish is a bit much for most.
Also, all of the satellite internet plans I know of charge PER MEGABYTE OF DATA. This means that using it for anything other than just the occasional check of e-mail and downloading GRIB files can get very expensive rather quickly.
pacific ocean?
Anyone?
post #27 of 43 Old 01-18-2010
i keep forgeting to post this but most wireless routers default to a max range of 2000 meters. so pretty much any normal router will not allow you to connect past about 1 and a 1/4 miles no matter how much power or antenna size you have.
scottyt is offline
post #28 of 43 Old 01-18-2010
Sunsets and Warm Beer....
LandLocked66c's Avatar
This is what I plan on using. Just flash it with DD-WRT and configure it as a repeater and call it done. I use the same router to expand my wireless foot print here at the house.
slax likes this.
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #29 of 43 Old 01-18-2010
Using DD-WRT firmware you should be able to tweak your wireless router to maximize your range. That's assuming it is available for said router?
S/V Frida
post #30 of 43 Old 01-18-2010
I've used the hardware mentioned in my previously linked to blog post to setup several WiFi links that are over two miles in length.
Re-naming the boat pirateofcapeann General Discussion (sailing related) 130 01-07-2014 11:14 AM
New name (I know, I know) owlmtn Boat Review and Purchase Forum 13 12-13-2009 07:46 PM
help with lifes dream kimby Boat Review and Purchase Forum 37 12-02-2009 11:32 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
