Hypervent or Equivalent? - seeking condensation solution for under berths - SailNet Community
post #1 of 7 Old 05-21-2014 Thread Starter
N&N
Hey All!
I've been researching solutions for the dampness that forms under our sleeping berths. I have read great reviews about HyperVent, but wonder if there any other materials that you may recommend?...perhaps something a bit cheaper? (HyperVent website says $12/sq. ft.)
I'm all for DIY, so if there is a non-marine material I can use, that would be great!
Thanks in advance!
Natalie
N&N is offline
post #2 of 7 Old 05-21-2014
Re: Hypervent or Equivalent? - seeking condensation solution for under berths
That price is ridiculous. Defender sells 39" wide rolls by the foot for $9.99. That would be about $3/sqft.
I did every berth aboard with it. Makes a huge difference.
Jeanneau 54DS
Minnewaska is offline
The Following 2 Users Say Thank You to Minnewaska For This Useful Post:
BluemanSailor (05-22-2014), N&N (05-22-2014)
post #3 of 7 Old 05-21-2014
Dog8It's Avatar
I have been using this Froli Sleep Systems by Nickle Atlantic, LLC and condensation has never been an issue. More comfortable rest comes as an extra bonus.
Doolittle
Com-Pac 35
The sea, once it casts its spell, holds one in its net of wonder forever.
Jacques Yves Cousteau
Dog8It is offline
The Following User Says Thank You to Dog8It For This Useful Post:
N&N (05-21-2014)
post #4 of 7 Old 05-22-2014
How easy is the Froli system to get underneath? All our berths have storage below. Fairly simple to just pull the hypervent aside and lay it back down.
Jeanneau 54DS
post #5 of 7 Old 05-22-2014
On a MUCH cheaper note, I have been using and am happy with these:
available at box hardware stores etc. I've been using mine for two years.
Multihullgirl is offline
The Following User Says Thank You to Multihullgirl For This Useful Post:
N&N (05-22-2014)
post #6 of 7 Old 05-22-2014
Old enough to know better
I have seen people use the mesh material that you use on a roof cap under the asphalt shingles. It is cheaper than the price you listed, but not than the price from Defender. The other issue is the roofing material comes in narrow rows of like one foot. Seems it would shift around.
miatapaul is offline
The Following User Says Thank You to miatapaul For This Useful Post:
N&N (05-22-2014)
post #7 of 7 Old 05-22-2014
Dog8It's Avatar
Well, it is fairly easy - I just roll it up to access the storage below as the springs are connected to form a sheet of sorts. On the other hand, if I had to do it on a daily basis, I probably would have a different opinion as after every move / role-up there usually is a connection or two that needs to be adjusted. Not a big deal but on a very frequent basis may get annoying.
Doolittle
Com-Pac 35
Dog8It is offline
Tags
condensation , damp , foam , liveaboard , mildew
EG vs PG--If marine toxicty is equivalent, why not use EG for non-potable systems? pdqaltair Gear & Maintenance 0 01-06-2013 12:44 PM
ATF-A Equivalent Transmission Fluid pras Diesel 1 05-22-2011 02:32 PM
Sail Trim Tips for Catalina 27 or Equivalent?? SanDiegoRacer Racing 7 07-14-2009 07:59 PM
Equivalent of snatch block, but for clutch or cam? labatt Gear & Maintenance 14 04-10-2007 04:18 PM
US equivalent of RYA? RichardKnight Learning to Sail 1 08-01-2002 04:27 PM
