Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
Old 06-04-2007
David A is on a distinguished road
Live Aboard
My wife and I are about to retire and live aboard. We are considering getting a convection microwave oven. I dont know how moch we are going to be in slip and how much on ancor yet. We would appreciate any advice or suggestions we can get. We have a 1980 33' Morgan OI Pilothouse.
Thanks,
David
Old 06-04-2007
btrayfors will become famous soon enough btrayfors will become famous soon enough
What cha lookin' for? Advice on retirement? On living aboard? On microwave ovens? On how much time to spend at anchor? On systems to power your microwave oven?
Give us just a hint....
Old 06-04-2007
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
How much do you use a microwave at home? It won't change much.
Old 06-04-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
How big is your inverter ?
S/V Scheherazade
Old 06-04-2007
How big is your house battery bank? Also, what charging sources do you have on the boat? Microwave ovens tend to draw a fair amount of juice..
Old 06-04-2007
uspirate's Avatar
Trim for Sail
uspirate has a spectacular aura about uspirate has a spectacular aura about uspirate has a spectacular aura about
how big is your Bank?
signature
BJ & Nimfa
S/V Flocerfida
Old 06-04-2007
camaraderie's Avatar
moderate?
David...there is no problem with a micro/convection at the dock and indeed it is an excellent way to cook since you can get excellent results without heating up the boat as much.
Convection is pretty much out of the question on the hook but you can use the microwave only option to heat veggies and stuff briefly if you have a good inverter and battery bank.
Old 06-04-2007
Microwave
It was a question on regular microwave or convection microwave oven ?
David:
Old 06-05-2007
David:
Kind of depends on how much time you'll be at a dock with shorepower, and how much time you spend on the hook. If you're mostly at a dock, get the convection/microwave... if on the hook, get the microwave only oven.
You'll still need a fairly hefty battery bank and inverter to run it though. Also, you will need to have some non-engine-based way of charging your batteries—either wind or solar.
Old 06-06-2007
GentleBreeze is on a distinguished road
Worked for Sharp Electronics many years up to '98 and worked in the consumer electronics area which covered microwaves.
Be aware that a convection M/W must be vented. Manufacturers make vent kits for each of their convection units. It would be unsafe to operate a convection M/W in the confinds used by regular microwaves as the heat would be too great and pose a fire hazard. Consult the installation specs with your oven before purchasing it to make sure you have room to install and meed space requirements.
Proper use of the Traveler PDixon Boat Review and Purchase Forum 12 01-02-2008 02:29 AM
Live Aboard Locations CliffL Chesapeake Bay 12 06-02-2007 08:14 PM
Live aboard question kestrelsail Living Aboard 7 12-31-2006 03:35 AM
Live Aboard Contributors wanted newuser Living Aboard 0 03-30-2004 04:28 PM
Marina Del Rey live aboard question Myblueheaven Living Aboard 1 10-14-2003 11:22 AM
