1 - You are not the marina DJ (keep your noise to yourself)
2 - Halyards should be tied off
3 - There are no maids, please be neat in the restrooms/showers/laundry
4 - Dogs should be leashed and trained not to bark at every little thing
5 - Run fresh water through the
pump out when completed
6 - Finger piers are semi-private
7 - Think of others first...communicate with your neighbors (don''t start a sanding job when the neighbor is putting the final
varnish coat on, etc.)
8 - Contain your overflow stuff
Anything else?
