Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
  #1
Old 11-17-2007
HoffaLives's Avatar
HoffaLives is on a distinguished road
How do people do their water?
And I don't mean pee -that's another thread -; I'm wondering if people have hooked their boats up directly to city water or do they use tanks and pressure pumps?
It has been a real learning for me as we use our water tanks and find we go through about 75 gallons in just over a week. I blame the wife - she has this obsession with cleanliness and showers every day. Rather Petite Bourgeois that.
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat:
  #2
Old 11-17-2007
k1vsk will become famous soon enough
A simple "T" onto the high pressure side of the 12V water pump hookup with a pressure reducer hull fitting and a back flow preventer on that side of the pump and you have all the watet you'd ever need. Just make sure to shut it off when you leave the boat.
  #3
Old 11-17-2007
Slooptattoo's Avatar
Senior Moment
Slooptattoo is on a distinguished road
Smile Dockside Water
Hoffa,
As a full time, long time live a board, I use dockside water normally. I have a hydrallic quick disconnect much like motor yachts use and immediately inside the lazerette where the connection is, I have a pressure regulator. I've found that the further north we travel the higher the water pressure. I have mine set to 30 psi and it seems to keep us pretty happy. The only thing you MUST do is to turn the dockside water off when you leave the boat. Even if it's a five minute trip, we turn it off and back on when we return. I don't turn the water heater off and I don't turn on the boat pressure pump. I keep my water tank (150 us gal) full and flush it once a month on a schedule to avoid stagnation. This is just FYI, but that's how we've been doing it for some time. The pressure regulator and the turning off of the water on departure is a must in our case. Murphy's law says that the plumbing lines will rupture as soon as I'm 1/4 mile away. Have a good Holiday!
Mike and Joyce, S/Y "Tattoo"
"There is nothing- absolutely nothing-
half so much worth doing
as simply messing about in boats."
The Wind in the Willows
  #4
Old 11-17-2007
Lion35 is on a distinguished road
I've always used my tank (100 US gal) but I've been thinking a lot about shoreside preasure water lately. I always thought it would take a routine like Slooptattoo, shuting of the water everytime you leave the boat. Let us know if you switch over and how unlimited H2O changes things for you.
  #5
Old 11-17-2007
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Because of the possibility of flooding the boat just when you turn your back, I prefer not to hook directly to city water feed.
Filling the tank regularly also keeps fresh water in rotation in the tank.
I make sure I run the hose for a few minutes before inserting into the tank fill.
  #6
Old 11-18-2007
jerryrlitton's Avatar
Oathkeepers member
jerryrlitton will become famous soon enough
Send a message via ICQ to jerryrlitton Send a message via MSN to jerryrlitton Send a message via Yahoo to jerryrlitton Send a message via Skype™ to jerryrlitton
I get a shot of single malt, pass a tumbler of water overhead and whisper water very softly, tossing it over my left shoulder. Then drink the scotch.
Jerry
"People that values its privileges above its principles will soon lose both."
Benjamin Franklin
"Those who hammer their guns into plows will plow for those who do not."
Thomas Jefferson
"First they ignore you, then they ridicule you, then they fight you, then they agree with you."
Ghandi
  #7
Old 11-18-2007
Valiente's Avatar
Try Irish single malt, Jerry. I recommend Redbreast Pot-distilled. Whisper uisge over it.
  #8
Old 11-18-2007
Oathkeepers member
Hey buddy, hello from Chicago. I will try that but I may have more then a little difficulty pronouncing uisge. However after a few shots it will not matter much eh? By the way I just took a whirlwind tour of your western part of your beautiful country commencing in Tuktoyaktuk, St George, Kamloops then ending in Victoria, BC.
Jerry
Benjamin Franklin
Thomas Jefferson
Ghandi
  #9
Old 11-19-2007
Oathkeepers member
If anyone is interested I took pictures from the helicopters between Tuktyaktuk and Victoria. Let me know if you want to see them.
Jerry
Benjamin Franklin
Thomas Jefferson
Ghandi
  #10
Old 11-19-2007
RandyonR3's Avatar
Cruising
RandyonR3 is on a distinguished road
Hoffa
I've built a pretty cool setup for water, as we often leave the docks for months at a time.
I've installed 2 tanks, 50 gallons each. the inside water is pulled from the port tank. The other tank is fed from either the watermaker or outside fill. the water is transfered from starboard to port with a transfer pump.
The idea behind this is that at any time, we know we have at least 50 gallons of water. If away from the dock, we transfer the water and then turn the watermaker on... I feel we have more control on how we use the water.......
You may post attachments
You may edit your posts
What's your biggest bonehead move sailing? CharlieCobra Seamanship 471 2 Weeks Ago 10:42 AM
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
Understanding Tidal Currents Jim Sexton Seamanship Articles 0 08-05-2003 08:00 PM
SEO by vBSEO 3.6.1
