09-17-2008
Basically, most of the ice eaters are just fans that circulate the warmer, denser water from down below up to the surface and prevent the surface from getting cold enough to freeze. The shallower the marina slip, the more difficult this is to do, since the warmer water generally requires some depth.  It is basically a big prop in a housing that circulates water.
With a 40' boat, you'd probably want two of them as a guess...
BTW, I haven't used them in a while or set them up in about 10 years... so YMMV.
