Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
  #51 (permalink)
Old 10-23-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Originally Posted by wind_magic View Post
Good idea, I had not thought of this.
Having never used a bladder tank, how is it filled, by gravity like any other tank or would I also have to pump water into it ?
Thank you!
Thinking more about this, I think what I would rather do is just use my regular water containers and have a water pump so I wouldn't have to lift them out of the dinghy. Anybody have a suggestion for a 12vdc water pump, is there a place around that sells that ? Maybe a small bilge pump is what I am looking for, something that wouldn't put oil into the water ...
What are you pretending not to know ?
  #52 (permalink)
Old 10-23-2009
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
Do you have pressure water on your boat? Buy a spare of exactly that pump and use it to pump from jerry jugs or any container, and you'll also be able to swap out directly if your pressure pump fails.
sail fast and eat well, dave
S/V Auspicious
AuspiciousWorks.com
beware "cut and paste" sailors.
  #53 (permalink)
Old 10-24-2009
RealityCheck's Avatar
RealityCheck is on a distinguished road
Originally Posted by sailing320 View Post
If I am traveling, what is the easiest way to find mooring locations?
The Updated Cruising Guide for the area your in.
I prefer a sailboat to a motorboat, and it is my belief that boat sailing is a finer, more difficult, and sturdier art than running a motor.... Jack London
  #54 (permalink)
Old 10-24-2009
cruising all I can
joethecobbler is on a distinguished road
Filling a bladder tank in the dinghy to transfer to your onboard tank is easy. You fillit the same way you fill the jerry cans (usually from a water spigot or hose). The advantage is, the bladder tank rolls up small when empty. And can carry quite alot of water when full. It also will/can lie in the bottom of the dinghy easier than the jerry can balancing act (sliding around etc.
Getting the same type of pump as you already have aboard is a good idea, however your pressure water system pump probably is prety costly and not durable enough to be kncked about in a dinghy and possibly inclimate weather conditions.
Harbor freight sells a 12 volt stainless pump body model for about $30 with standard hose fittings it can be attached easily to the bladder tank.
I guess if you didn't have a bladder tank you could still fill the jerry cans then pump into the main tank, untill you convinced yourself that this method is worthy . Then I would guess you would tire of lugging the cans and just get the bladder tank.
ALso to the sailor asking about mooring locations. why not just anchor ? it's free ! and you never have to wonder what your actually tied to when the weather kicks up, as you will have lowered the ground tackle yourself.
  #55 (permalink)
Old 10-24-2009
zeehag's Avatar
zeehag is on a distinguished road
as joe says---your tackle is better than a mooring unknown...there is always a place to anchor---there may not always be a place to moor----mooring requires using someone else's tackle--not your own--and there are steps to hassle as re: finding one without a long waiting list, much less one in the area you wish to use.....there may not be a field ion the area you seek a mooring in....etc.......in many places there is the ability to anchor near a mooring field--not in redhook, st thomas, usvi, however------but many other areas that is a possibility--and moorings cost money---anchoring, most places, does not.......
Last edited by zeehag; 10-24-2009 at 07:18 PM. Reason: boatkat isunt a gud speeler and fergits stuff......is killing burdeeez....
  #56 (permalink)
Old 10-25-2009
Mermaid Hunter
A lot of people carry a spare pressure pump anyway, so using it for water transfer is a cost savings over an additional transfer pump.
I don't carry mine in the dinghy. Only when I get full water jugs back to the boat do I pull out the spare pressure pump (and incidentally General Ecology pre-filter) and transfer water.
I similarly use my X-Changer oil change pump to move fuel from diesel jugs to the boat tanks.
I have a very bad back and work hard to avoid putting any kind of strain on it. Using pumps I carry anyway to transfer liquids helps a lot.
S/V Auspicious
AuspiciousWorks.com
  #57 (permalink)
Old 10-25-2009
zeehag's Avatar
check out noonsite--they have almost everything needed for cruising
Mooring systems GoodOldBoat Good Old Boat 3 10-09-2007 09:05 PM
The Mechanics of Mooring Mark Matthews Seamanship Articles 0 05-19-2002 08:00 PM
