04-11-2008
Natural speed is equal to sqrt (lwl). Hull speed is equal to 1.34 * sqrt (lwl). IIRC, one indicates the approximate point at which the curve for power vs. boat speed goes from linear to geometric, the other where it goes from geometric to exponential.
Basically, once a displacement hull is at hull speed, all putting additional power to the boat is going to do is cause the boat to squat for the most part. At natural speed, increasing power will result in diminishing gains in boat speed.
Originally Posted by xort
How is this different than hull speed?
