Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
  #21 (permalink)
Old 08-08-2008
SVAuspicious's Avatar
Mermaid Hunter
SVAuspicious is on a distinguished road
I live aboard my 40' sailboat. I run everything except a/c off one 30A circuit, including *way* too much computer equipment. As it happens, I don't use a coffemaker (percolator instead), but otherwise I basically live as I did ashore.
I have a second 30A input for the a/c (a 12k and a 7k BTU unit). For winter heat I use a Webasto diesel heater, but if I was going to use electric heat I would put carefully labeled outlets on the a/c circuit to plug ceramic heaters into (again, distributing loads across the two inputs).
On shore power, the big consumers for me (from biggest down): a/c, water heater, battery charger, computer equipment, little stuff.
  #22 (permalink)
Old 08-10-2008
Trekka's Avatar
Seasoned Salt
Trekka is on a distinguished road
Originally Posted by theartfuldodger View Post
Well for heat we live aboard our 33 O/I Morgan in Newfoundland and use one 1500 watt heater, and only turned to the second postion, this gives us lots of heat, sometimes we open a hatch to just cool.
That's a lot less than I would expect. Have you insulated? If so, what did you do? Do you really have warmth from the forepeak to the aft cabin during winter?
thanks
Trekka CSY33
Re-naming the boat pirateofcapeann General Discussion (sailing related) 111 04-24-2012 02:39 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
Performing in Light Air Brian Hancock Learning to Sail Articles 0 01-15-2003 07:00 PM
