beginners questions - Page 2 - SailNet Community
post #11 of 44 Old 09-17-2008 Thread Starter
thanks for the suggestion of tidewater yacht agency. it looks pretty good. i looked at the "rates" page and for a 1-3 month transient stay, it came out to $350 per month for 27 feet. i didn't see a price for long term live aboards though. maybe i'll give them a call in a few days. research has been put on the back burner seeing as i have a chem test tomarow.
and thanks for the reality check on the cost of living chuckles. i've considered most of those already, but i wasn't aware of the insurance costs. i'll have to look into the different coverages available. if it were a car, i'd definitely be going for liability. i basically just want to be covered in a lightning strike if that is an option.
KasbeKZ is offline
post #12 of 44 Old 09-17-2008 Thread Starter
it looks a long way away on google earth, but map quest says 15 minutes. probably without traffic. or maybe a new bridge has been put in since google was updated. thanks for the suggestion. i'll be running over there next week to see what the deal is
KasbeKZ is offline
post #13 of 44 Old 09-18-2008
New liveaboard questions...
Hello All,
So glad to find other lunatics who live on thier boats in cold climates! I just bought a Pacific Seacraft, Crealock 37, nice boat, NO HEAT; unless you count that Force 10 (otherwise known as the "fireplace"). I like breathing oxygen so I'm considering electric CERAMIC radiant heat. Any feed back out there??? Some sources say a ducted forced hot air system is really better to reduce the condensation and heat the area along the hull (inside the storage areas of the setees, ect)? Talk to me people, I'd love to hear from someone north of SC, USA!!! I'm in Rhode Island and may have to shovel snow off my dock in Jan & Feb. Anybody using heat tape on thier water lines? Does it work in Feb? Running water will be a luxury this winter but ANY advice on this system is appreciated. I'm just bought this boat so I need to insulate it too...suggestions??
Thanks in advance...Bethann
sailorgirl60 is offline
post #14 of 44 Old 09-18-2008
If you're talking an AC powered ceramic radiant heater, I'd say don't do it. They're a fairly dangerous fire hazard. If you need to go with AC-powered heat, I'd recommend the larger oil-filled radiator type heaters. They're far safer, especially on a tippy boat.
As for forced hot air—those systems are pretty good, like Webasto, but require regular maintenance and fueling, which a AC-powered oil-radiator isn't going to require. An electric powered heater is also going to be a much drier form of heat as a general rule, compared to LPG, Diesel or Kerosene fueled heaters, since there is no combustion process going on. Adding fans to what ever system you use is a good idea to circulate air through all the lockers and such.
Never heard of using heat tape on the water lines.. wouldn't recommend doing it either.
As for insulating the boat, if the boat has removable ceilings and overheads, it would be well worth filling any such space behind them with foam insulation and a mylar radiant heat barrier film. This would seriously increase the insulation value without adding too much weight or bulk.
Originally Posted by sailorgirl60 View Post
Hello All,
sailingdog is offline
post #15 of 44 Old 09-18-2008
jimmalkin's Avatar
We've been living aboard since 15 April in Jersey City NJ and MV during the summer until Labor Day. We generally haul in early December. Learned the following:
SD is right about the insulation and the fans - I'd add that you can get rigid foam insulation and cut it to hatch size and portlight size and save a lot of heat. I second the oil filled radiators if you have a/c. We've found that forced hot air from a reverse cycle air conditioning system can't extract significant heat from the water around the boat in the Northeast winter.
And it is hard to keep decks, piers and docks shoveled off and clear of the ice, frozen slush and hardpack that builds up under snow. On the other hand, if you accept global warming, it may be balmy in RI this winter?
White Rabbit
Vineyard Haven
jimmalkin is offline
post #16 of 44 Old 09-18-2008 Thread Starter
sailingdog, aren't you the one that told me not to threadjack on one of my first posts? just wondering what i did wrong and sailorgirl didn't....
camaraderie, i called up tidewater yacht agency, and all they would say is that they are filled up and not taking any new renters and aren't expecting to. it's disappointing, because from what they said on their website, i was looking at $350 a month there. that would have been AWESOME. but i'll probably give a call back about every month to see what's changed. thanks again for the suggestion. that place is nice, and only 15 minutes away!
KasbeKZ is offline
post #17 of 44 Old 09-18-2008
KasbeKZ-
AFAICT, SailorGirl's post is pretty much on topic when it comes to living aboard a boat... and probably relevant to you, if you were to choose to liveaboard a boat.
Your opening post is about making the decision whether to live aboard a boat or get an apartment. Last I checked, you're going to have to heat a boat if you're living on it, since, even in Norfolk, Virginia, you still get snow and relatively cold weather in the winter. BTW, I lived in Norther Virginia for seven years and my in-laws live in the Tidewater region of Virginia, so I am pretty familiar with the weather conditions down there.
A boat that isn't insulated is going to be pretty miserable to liveaboard, and trying to heat it with a diesel, kerosene, or propane heater, when dockside AC shorepower is an option, is a bad idea IMHO. Electric heat is safer than combustion-based heating processes in a small boat, since there is no risk of CO poisoning, and a much lower risk of fire, especially if you're using the oil-filled radiator style heaters.
BTW, you're referring to the Winter Liveaboard thread, where you asked:
Originally Posted by KasbeKZ View Post
here's a noob question. i hear a lot of talk about diesel heaters and such being used on these boats. what size diesel heater may be appropriate for a 27-30 ft boat in the Chesapeake area? also, what about the positioning of the heater and protecting the surroundings from getting too hot? i wouldn't want to catch it on fire... would this heater just be sat right in the middle of the salon, or would it hang?
IMHO, your post wasn't so much about winter liveaboard but about sizing and installing a heater, which wasn't really on the topic of living aboard a boat in the winter, but more a gear and maintenance issue.
post #18 of 44 Old 09-18-2008 Thread Starter
ok i understand. it wasn't a real complaint, i was just wondering what you were basing these instructions on
KasbeKZ is offline
post #19 of 44 Old 09-18-2008
Umm... my twisted interpretation of the world as I see it.
BTW, keep on top of the Tidewater yacht agency, since things can change pretty quickly....
post #20 of 44 Old 09-18-2008 Thread Starter
will do. thanks much.
KasbeKZ is offline
simple questions after first night on my new boat dodgydingo Sailboat Design and Construction 21 09-14-2008 02:53 PM
Lots of General Questions jcook5003 Cruising & Liveaboard Forum 30 10-25-2007 04:08 PM
Looking to buy a boat in the DC area and have some questions FRRizzo111 Boat Review and Purchase Forum 10 06-02-2004 06:20 PM
New X-46 -- New Intro -- First Questions John-A Boat Review and Purchase Forum 8 01-29-2004 08:21 PM
a few specific design questions jbarros Boat Review and Purchase Forum 5 10-02-2003 02:13 PM
