Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
Old 12-11-2008
lofty22810 is on a distinguished road
whats the best bottom paint for racing
I am stripping all of the 27 yrs of bottompaint off and will be applying several coats of new...except this time i want to put a faster bottom on her and was curious to what yall suggest?? lancer 36
Old 12-11-2008
It depends... do you keep the boat in the water or not?
Old 12-11-2008
yes saltwater,NC
Old 12-11-2008
ASA and PSIA Instructor
Racers like hard paints like VC17 or Baltoplate.
Note that the bottom paint wont be any faster than the quality of the bottom prep underneath the paint. if you you don't spend 5-10 full days fairing the bottom with microballoon filler and a long board, don't bother with a hard bottom paint, just roll on some ablative stuff and go sailing...more slowly.
Old 12-11-2008
SF brings up a good point... how fair is the bottom of your boat. If you do fair with a microballoon filler, coat it with a skim coat of unthickened epoxy, otherwise, the microballoons that are sanded can absorb water.
Since you're bringing it down to the bare hull, you might want to barrier coat it at this time while you're at it.
A good hard modified epoxy paint is probably your best bet, since you can sand it very smooth for racing...
However, IMHO, it won't matter too much, since you're on a full-displacement monohulll. If you really wanted speed, you'd be on a multihull....
bad dog.... bad, bad dog...
Old 12-12-2008
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
Bottom paints tend to behave differenty in different areas. Ask the racers in your area what they use and how they like. Your best bet will probably be to go with thier consensus.
I use Baltoplate and like it. However, note that none of these paints are going to be as effective as the cruising alternatives at keeping growth off; you will have to regularly clean your bottom.
-Jason
Old 12-14-2008
Mikelivingstone's Avatar
Mikelivingstone is on a distinguished road
How often is regular?
At Jason, I am considering switching from ablative bottom paint to try to better performance. But would like to ask how often does it have to be cleaned underwater?
Mike
Old 12-14-2008
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
Mike
The obvious answer would be, before every race.
John USYacht 27 "Cora Lee"
Old 12-14-2008
Yes, certainly before any major race I'll either get in and scrub or get a diver. In the meantime, I use a Dri-Diver (DRI-DIVER - Boat Hull Cleaner, Remove hull growth from the dock) to keep the hull free of too much growth accumulation. I'll scrub with the Dri Diver once or twice a month and dive (or pay a diver if it's cold) 7 or 8 times a year.
-Jason
Old 12-14-2008
NOLA..thanks for the link..
we use an old fishing net with a line tied on both ends..tyhe ropes go up the and up the hull on each side to a person on each side standing on the deck
then one pulls the other one lets go a little ,and both move back and forth like a saw, and walk back
Confessions of a bottom feeder PracticalSailor Gear and Maintenance Articles 9 06-18-2008 04:33 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
