Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
  #31 (permalink)
Old 05-25-2009
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
I've lived on a Paceship PY 26 (fin keel/4.5 draft) for almost 2 years now. It's fine for 1 person, but a couple would be cramped.
The Paceship Website Homepage has all the specs
The Centerboard model is probably better for trailering, mine needs a tractor trailer.
-6 ft. headroom
PY 26 has 6'1" except at door headers, cabin area is roughly 7x7.5'
-26 or 27 ft. (as far as I know, the max. length that still qualifies as trailerable)
Trailerable = gross combined weight, pickups are limited to 2-3000 lbs. gross combined weight, a tractor/lg. car carrier type truck would be needed to stay legal.
26' 6" x 9.5' beam (needs wide load signs) and 6400 lbs. empty, I'm around 7200+ lbs. now.
-outboard engine (avoid hassles of inboard)
I have the outboard option and it gave me room for a 45 gal. fresh water holding tank and other misc. storage where the inboard would have been. I'm currently moving my 3 batteries up front behind the head holding tank (under V-Berth) to help balance the extra 370 or so lbs. of water under the cockpit. I also have a fume sniffer (propane/butane/gasoline/sulfuric acid etc.) going.
-marine head
Head w/ holding tank and I also added a shower w/ elec. pump.
-at least one berth with a door: fore or aft, doesn't matter which
Cockpit> Cabin > (door) private head > (door) V-Berth w/ small stand up changing area.
I heated it w/ a 4-8k btu Propane space heater and it was 72F+ inside w/ 0-10F outside winter temps in Rhode Island. I also insulated it w/ the foil over bubble wrap flex. insulation.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Small Liveaboard Cat search djeeke Boat Review and Purchase Forum 72 10-31-2009 08:41 AM
Choosing a small liveaboard bluewater cruiser daveyjustin Tartan 13 07-24-2009 10:27 AM
Keel nuts, bolts, loctite, et al.. rperret Gear & Maintenance 1 04-27-2008 11:23 PM
Small Boat Cruising David Schaefer Cruising Articles 0 06-09-2004 08:00 PM
the perfect 20'' cruising boat? jbarros Boat Review and Purchase Forum 14 04-18-2004 06:45 PM
