Marine Wireless Internet Help Please...!
Hi All !
I was wondering if anyone had some sound technical advise for me as far as dockside internet access is concerned? I currently connect through a marina wireless internet provider using a WaveRV (Radiolabs) USB antenna connected to my desktop computer. It has the hardware built in to the antenna itself and has a 15' USB cord with the related software installed and running on my computer. Typically my connection speed is on average 10Mb/sec download and 0.8-0.9Mb/sec upload speed using the "Speedtest" website as an indicator. I want to be able to run a wireless signal throughout my boat in order to give me more flexibility in where I can place my desktop as well as to get rid of the direct USB connection to it. I also plan on using other wireless devices (AppleTV, Skype, etc) so I want to ensure the best possible signal quality. I require internet access ONLY while at dock and I am currently about 300' from the provider signal on shore. I see a lot of other systems with external non-usb antennas, bridges, routers, PoE, etc and this really seems like overkill if I don't need internet access while away. So it seems my best remaining options are: 1. Keep the usb antenna, purchase a small notebook computer running WinXp, install the antenna on that and then bridge this connection to my Apple Airport Express wireless access router using the Local Area Connection adapter on the notebook. 2. Buy a high power wireless router. Should this in itself provide a good enough connection to the ISP connection point if the router was mounted inside my boat? This would eliminate both the USB antenna and the Airport Express from the scenario entirely. I'm not entirely sure why a bridge would be needed for my particular application. I am of the understanding that a bridge is needed in stand-alone systems that use an external antenna to connect to the chosen router that will be used? So in essence in scenario #1 above the notebook would be acting as the "bridge" between the usb antenna and the Airport Express router? Am I at least heading in the right direction here? I apologize for my ignorance here. Thoughts, comment or suggestions would be greatly appreciated. Cheers! |
I'd really recommend you read this post, which I wrote addressing this exact issue. :)
I'm not sure what the etiquette is here, so mods - delete my post if it's inappropriate.
The problem you mention is a big issue with boaters - how do you easily get shore based wireless access while also getting wireless access inside your boat. The answer to the question is that there are a few very expensive ($1,500+) devices which offer both access point capabilities inside the boat, and connectivity to shore. The alternative is to buy something like an Engenius for shore based access, hook it up to a wireless router on the inside of the boat (which are USUALLY, but not always AC powered) and that will give you what you want. You still have to deal with a big thick cable going up the mast for your antenna, or hanging something off your halyard. You will usually get signal loss if you have to run a long cable. Anyway (and here's the part the mods may have to delete) - a friend of mine and I (we both own IT companies and met cruising) got sick of having lots of cables, high power draw, signal loss, multiple devices, etc. for the problem you describe. Instead of complaining, we're in the process of building a product. It's not available yet (we expect in 2-3 months it will be ready), but it will be a small, low power device that combines the access point and the shore system in one unit and lets you create a wireless cone of access on your boat that's always on. This will allow us to support phase two, which will be NMEA integration and an iPhone/Touch application for things like an anchor alarm, instruments, etc. Phase two is a ways down the road. Anyway - no product announcement yet, and when we have it we'll look at the costs of sponsoring Sailnet and doing things the right way. In the meantime - mods (if you're listening) - would it be OK to post a thread asking people what they want to see in a wireless device? It's an opportunity for us to build it in to this unit and make something pretty cool for the cruising community. Or, if you need to, delete this post :) Chris |
Labatt-
The equipment and setup I describe in my post have the advantage of being DC-powered, low power draw, with very little in the way of signal loss or cabling. |
Thank you both labatt and sailingdog for your replies.
I suppose my main area of confusion lies in the difference/function between a bridge and a router; especially with regards to my particular application. On say a standard wireless router at home for example it creates a wireless link between a "cabled" modem and the users computer. Could the home modem itself be considered the "bridge" in this instance? Is this essentially what a home modem is? Since there is already a wireless internet signal being broadcast by the marina ISP would a standard wireless router not only transmit between both itself and the ISP as well as itself and my computer thereby creating a usable internet connection link? Would my first scenario with regards to the USB antenna, a notebook and my current Apple router not work with the 2 devices "bridged" in the Win XP networking configuration? Again, this is to achieve a wireless network within my boat and while only at dock with no more than 400' between my vessel and the ISP signal on shore. I'm essentially trying to make this as uncomplicated as I can while using my existing equipment. Cheers! |
With regards to the actual bridging in the network configuration control panel are there any potential hardware conflicts that I should be aware of? Would I expect to see any sort of signal or quality degradation with respect to my average speeds I reported earlier with such a network setup? Thanks for the reply as it was very informative. Cheers! |
Once you have that set up as a bridge and/or router, then yes you could hook that to another wireless router and go about your business. But you don't even have to do that, you could install a second wireless card in the device you are turning into a router and it can use one of the wireless interfaces to connect to the access point, and use the other one to act as an access point for devices on your boat. To do that requires some research, it can be done with Linux but I don't know how you'd do it with another operating system. I would not expect your network speeds to change much. |
Thad,
Were I in your situation I would get a POS old/free laptop and install Linux on it. Assuming you can get your USB wireless device working under Linux then the solution is essentially free. Edit - you'd have to make a cross-over cable to connect your router to the a Linux laptop. |
Could I not "bridge" both the new antenna hardware device (which has now actively connected to the shore ISP) and the notebook's built-in wireless card as it shows itself in the Network Connections page? I understand this is achieved by highlighting both devices one wants to bridge, right clicking on them and then using the "Bridge Connections" option that comes up. Shouldn't the netbook's built-in wireless card now act as a wireless internet access point thereby allowing me to connect to it with any other wifi device aboard my boat (computer or otherwise)? |
| All times are GMT -4. The time now is 09:28 AM. |
SEO by vBSEO 3.6.1
