Blogs
Go Back   SailNet Community > General Interest Forums > Living Aboard
User Name
  #21 (permalink)
Old 03-25-2005
sailnaway sailnaway is offline
sailnaway is on a distinguished road
Lightning Anyone?
In the summer of 2004 we were in St Pete Florida the capitol of lightning strikes. I had pulled into the Municipal Harbor to the cleanout station and a squal had come in. I was at the wheel and just stood off the dock waiting for the rain and wind to pass. KABOOOOM! my wife was looking out of the companion way at me when it hit. I had just at the exact second turned and without thinking grabbed the back stay to steady myself.It struck a boat shed about twenty yards astern but the branches must have jumped off and hit us. It burned my bare feet and the palm of my hand which was on the backstay. I was not sure if I had ahold of the wheel to or not as I was just sitting at idle.The burns were very minor,the electronics was fried. Every thing on the boat with a printed circuit was zapped and dead or only worked part way. Clock radio had no display but the radio worked. Tv zapped all wind insterments,depth speed ect zapped. Some of the stuff was not plugged in and was still fried.The only possible reason that I was not killed may have been this.We had been in the anchorage and when we pulled the hook a plow it came up with a big wad of mud. Since we were only going agout a mile arount the Pier at St Pete we left the anchor hanging down with maybe six feet of chain from the chock to the shank so the mud would wash off. That could have disipated some of the charge off.I talked to some Navy electronic survalance guys and ask about this and they said that they had hung plates in the water attached to ship masts from chains to take the charge away from the ship. I am thinking about some stainless chain and a couple of round plates so I can just use a d rind to attach them to the stays on both sides of the mast. I am thinking a circle of about 18inches across on a piece of chain long enouhg to get the plate at the same depth as the led or cast iron keel. a piece of thin wall clear plastic tube to keep the chain off the hull. This may or may not help but it makes it a little more grounded.Boats in salt water get hit less than boats in fresh water was something I found out. I don''t know how much being plugged into shore power helps if at all. I worked on a three story house in Colorado quite a few years back as a plumbing contractor. The lightning had struck th roof above the peoples daughters bed. It blew a three foot hole through the roof through the bed went through the floor lifting the hard wood about three inches hit the copper plumbing and blew the fixtures off the wall in two bathrooms ruptured the hotwater tank in the garage and set the place on fire. No one was home luckey for them becaause the daughter spent allot of time sitting on the bed yacking to her gitlfriends on the phone that was melted on a night stand.
  #22 (permalink)
Old 04-01-2005
rangerrobinfl rangerrobinfl is offline
rangerrobinfl is on a distinguished road
Lightning Anyone?
I was hit while connected to shore power last week on Gasparilla Island. My 30 amp breaker popped but the vhf antenna cable fried as well as the inverter on my fridge, GPS, anchor and steaming lights and breakers, and solar panel charge controller. I was probably lucky and that is good.
Rob
  #23 (permalink)
Old 04-06-2005
Billpjr Billpjr is offline
Billpjr is on a distinguished road
Lightning Anyone?
My 02.
I''ve lived in Florida 56 yrs and on sailboats 10+ along the ICW. Seen many boats struck and talked to people who were onboard or near during the strike. Boats I''ve looked at have had their aluminun masts melted and fiberglass hulls blown to pieces and sunk. Others were everything else from standing rigging bolts punched out to St Elmo''s Fire and no damage. The ones with "grounding wires" hanging into the water from a stay survived way better than those without...always.
When you get hit and it only takes out electronics it is a "feeder" strike. Study the numbers and you will see nothing survives a strike by the main bolt. It blows or melts everything from too much pressure or heat. The is no practical way to conduct that much juice to prevent damage.
The only thing you can do is bleed static charge away and prevent attraction. The highest point will be struck if charged more than the surrounding areas. I put a handheld miliamp meter on an aluminum mast. Everytime the wind gusted the needle pegged showing static charge. The static bled off faster with a grounding wire clamped to the stay and dropped in the water compared to nothing in the water. Anyone can do this test on their own boat to see. An old electrical contractor/sailor showed me this. He did mostly high voltage and lightning protection for buildings and farms.
  #24 (permalink)
Old 03-19-2006
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
The real reasons to bond the mast, stays, shrouds, and chainplates is to: 1)provide a protective cage for the crew to stay inside; 2) help prevent side flashes, where the current from the lightning bolt jumps laterally between to large metal components and injures or kills anyone standing in the way.
The DC grounding and bonding system for the electronics and through hulls should be separate from the lightning grounding system.
  #25 (permalink)
Old 03-21-2006
depthwish depthwish is offline
depthwish is on a distinguished road
shocking.experience
sorry.for.the.periods.again.no.spacebar.
yes.I.was.struck.by.lightning.off.of.chicago.about .2.years.ago.
we.came.through.a.squall.trying.to.get.in.and.were .faced.with.a.horizon.that.was.black.as.coal.
I.sent.everyone.down.below.and.put.on.my.foul.weat her.gear.
I.think.we.were.lucky.that.the.boat.was.wet.as.it. spread.the.hit.over.a.larger.space.
It.basically.blasted.my.hands.off.the. wheel.a nd.when.I.could.hear.again.I.was.so.glad.to.hear.m y.atomic.4.engine.still.running.
We.lost.all.the.electronics.and.anything.plugged.i nto.the.shore.power.110.system.
At.first.I.thought.it.was.a.near.miss.as.I.saw.the .flash.about.20.yards.off.the.starboard.beam.
I.later.learned.that.the.masthead.was.struck.and.t he.bolt.travelled.down.the.starboard.topshroud.and .when.it.got.to.the.imbedded.
chainplate.spat.out.the.hull.leaving.about.a.5.inc h.circle.of.delamination.and.a.pellet.sized.hole.o ut.the.hull.of.the.boat.
Since.then.I.have.read.up.some.and.asked.some.ques tions.
1...you.need.a.good.ground.from.your.standing.rigg ing.and.your.mast.and.the.water.whether.it.is.a.pl ate.on.the.hull.a.direct.connection.
to.an.external.keel.or.(in.my.case).4.10.foot.leng ths.of.1/4.inch.chain.and.a.quicklink.which.I.hang.off.of.t he.shrouds.on.both.sides.so.if.I.am.
under.sail.I.have.4.points.of.ground.into.the.wate r.on.both.tacks.
it.deploys.quickly.you.can.have.it.set.up.within.5 .minutes.of.spotting.foul.weather.
2...as.for.the.electronics.good.luck.I.have.instal led.inline.fuses.on.a.lot.of.stuff.and.set.up.two. separate.fuse.blocks.for.everything.but.
as.I.understand.it.with.lightning.it.can.jump.righ t.across.the.fuse.block.without.even.noticing.it.h as.blown.the.fuse.
I.know.in.my.case.the.old.style.socket.fuseholders .on.my.boat.were.blown.into.the.engine.compartment .like.little.22.bullet.
I.highly.recommend.a.hand.held.vhf.on.board.as.it. may.be.the.only.communication.you.have.after.a.str ike.
""lightning.never.strikes.the.same.place.twice....to o.bad.I.moved.my.boat""
Eric.Branson
"Zarathustra"
Islander.37
Chicago.Il.
  #26 (permalink)
Old 04-06-2006
While waiting for a squal to pass up in St pete I was at the pump out at the City Marina. I stood at the wheel raining like hell and boom. We were struck it stunned me burned my hand that I had used to grab the back staw to steady myself as I turned to look over my sholder to see where the boat shed behind me was.We lost all our electronics and some things that were sitting on the shelf and were not plugged in. Well the good thing is I am alive. We had our anchor hanging on about five feet of chain to wash the mud off which may have taken some of the current away.
  #27 (permalink)
Old 04-10-2006
Aloha27's Avatar
Aloha27 Aloha27 is offline
Aloha27 is on a distinguished road
A couple of years ago we were on our way home from Cape Breton's Bras d'Or Lakes in the middle of St. Georges Bay about 12 miles from any land when the sky darkened up REAL fast and we doused sail and fired up the engine to prepare as best we could for the fireworks display which we were sure was imminent. A bolt shot from cloud-to-cloud directly above the mast on our Aloha 27. Never have I been so close as to smell ozone and I'm in no hurry to repeat the experience.
Just remember... if you see the lightning bolt- it missed you!
Steve, Patti and Grace (Ship's Cat)
sv "Ever After"
Barrachois Harbour NS Canada
  #28 (permalink)
Old 04-11-2006
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
You will find many opinions, contradictory "studies", and no one set of rules for how to protect against lightning or mitigate the damage from it. The bottom line is that when a jillion volts decides to come calling, there is NO way to be absolutely certain of what it will do on your boat, no matter how it is rigged. Because it can jump, or induce currents, or create plasma balls, your best bet is to do some serious work on creating a good direct ground path (down the mast and into the water) and then learn that when the gods are bowling, you need to be ashore and indoors. Or, curled in a ball as far away from all metal parts of the boat as you can.
Very few things scare me the way the brute force of lightning does, and that's after reading all the opinions and studies. If you've ever been on a boat and felt your hair standing on end and heard static crackling off your radio antenna...."lightning protection" becomes a very remote concept.
Display Modes
vB code is On
LIGHTNING SHIMSHON General Discussion (sailing related) 37 07-24-2007 09:13 PM
Lightning as a Family Daysailer? catamount Buying a Boat 4 09-12-2004 04:34 PM
lightning protection soapstone Gear & Maintenance 3 08-07-2003 12:26 PM
Lightning Protection irishcajun Gear & Maintenance 1 07-15-2002 06:52 AM
Lightning 73mensailed General Discussion (sailing related) 1 06-18-2002 06:25 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
