Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
  #11
Old 02-27-2009
Scoopy is on a distinguished road
Creekmore John, I didn't see the picture of "Magic" in the travel lift until just now. The view of the hull below the water line looks a lot like "Georgia."
In the picture of "Magic" under sail, I think I see only one dorade vent. If it were on my boat, it would ventilate the head.
I also see a jack stay. Is your boat cutter rigged? I ask because the boom on "Georgia" use to extend over the cockpit with the main sheet trimmed with a winch on the after deck. I am told they took about 6 feet off the boom. Maybe this was done when the staysail was removed. Taking the staysail off without shortening the boom would have created a tremendous weather helm. Can you comment about whether the Creekmore 36s were cutter rigged?
Scoopy
  #12
Old 02-27-2009
CreekmoreJohn is on a distinguished road
Thanks for the quick reply. I haven't posted the minimum number of public posts to qualify for the private post yet.
There are two dorades, one over the head and one over the table. I interpret that Magic had the main sheet system aft of the cockpit at some point. The boom is the older boom round shape that permitted reefing by rolling the boom. There appears to be a gear system at the forward end with a lug available for a winch handle and the aft end has a ring around the boom on which the main sheet would have been attached. The topping lift is attached there. I have installed aa jiffy - slab reefing system for the first reef point. I could also see Magic actually having been a yawl at some point. Magic is not a real cutter rigged boat. We call the inner forestay a "baby stay" and have a very heavy storm sail for that stay. We rig the storm sail as a second foresail at times. With the boom at approximately 17 feet in length, Magic does develop weather helm rather quickly. The picture of Magic sailing shows her reefed with a small working jib. The sail arrangement is fairly balanced. I purchased a large (maybe 150) genoa through Atlantic Sail Traders and in light to moderate winds with the mail fully deployed, Maic is again well balanced and sails great. With that much sail up, other folks on the lake really take notice and comment often how beautiful and classic Magic looks. As is the case with most folks, we have lots more pictures of other boats than we do of our own. I have many pictures of our efforts at refurbishing Magic. My sons helped greatly. I'll package up some and post them.
  #13
Old 02-27-2009
Yah, baby stay sounds like a better term.
Your photo shows the very long boom -- probably like Georgia's used to be. Our boom is round also, with a worm gear drive with a special winch handle for roller reefing. Now, of course, with bails on the underside of the boom for the main sheet and traveler system over the cabin house, we have to use slab reefing.
Georgia has no vents -- dorade or otherwise -- on the cabin house. The forward hatch cover at an angle is a nice wind scoop. Our climate and water temperature are cooler than yours so the extra ventilation is not needed.
I think the original main would have been too big without more headsail. Weather helm would result. Your story confirms this.
Do you have a centerboard?
I think I can see the split backstays.
We have a large window on the forward face of the cabin house. Eighth inch polycarbonate. While the polycarbonate is well secured with lots of screws, I have some concern about a large wave breaking over the bow coming aft and punching out the polycarbonate. Where the aftmost ports are, large windows have been installed. At least the window materials is 1/4 inch. Waves can be huge and steep in the Great Lakes.
Is the traveler for the jib sheets a flat brass bar? Is the bar mounted on the top of the rail? Does the bar have holes in it at regular intervals and do the cars have thumb screws that drop down in these holds to hold the car in position?
Is the afterpart of your cabin house raised compared to the level of the cabinhouse where the mast is stepped on the deck? It doesn't look like it in the photo.
Well, enough questions. Let me know if I am asking too many?
Best regards.
  #14
Old 02-27-2009
J24mark is on a distinguished road
Hey Scoopy,
I am creekmore johns son, I might be able to help out with a few of those questions.
1) The boat is not a centerboard.
2) It does have split backstays.
3) It does not have a large window where you are talking about, we just have the 8 ports 4 on each side of the cabin.
4) The track for the jib sheet is a brass bar sitting on top of the toe-rail.
5) The cabin top is completely flat fore to aft.
It would be cool to see some pictures of your creekmore, I will try and upload some more to show the interior and exterior. We have hundreds, haha. Keep the questions coming, it's nice to be in contact with another creekmore owner. Thanks again.
  #15
Old 02-28-2009
Creekmore 36s
J24Mark: Thank you for the answers to my questions and for the invitation to ask some more.
The most curious piece of information is the fact that your Creekmore 36 does not have a centerboard. Mine does. I should think this is a major design change. The centerboard slot would have to have been formed when the keel shell was filled with ballast. The centerboard would change the location of the center of resistance and this with the size and location of the sail plan would affect helm balance. Maybe some others with additional knowledge of the Creekmores can help us.
As I mentioned in a previous post, my boat measures nearly 37 feet overall and 10 feet on the beam, a little larger than your Dad's 36. From the photos, the hulls look remarkably similar.
The aft part of our cabin house is raised and two small windows have been placed in forward-facing slope. The companionway is not on center, but rather to starboard. This allows the dinette to be port. The dinette can be made up in a double berth, although one person sleeps mostly under the side deck.
I will work on the photos tomorrow.
Thanks very much. Scoopy
I will find some photos to exchange with you. I will have to figure out how to attach them to messages in this thread.
  #16
Old 02-28-2009
Thanks Scoopy, I am excited to see what this creekmore looks like. My father and I have been discussing the subtle differences, but as you may know, these were custom made to order from the buyer. Our HIN says our boat is a 67 but we have been saying it is a 1960 because thats what we were told word of mouth. Does your boat have a sketchy history as well?
All I know about these boats is the 1"+ hull thickness with NO core material, our boat sometimes gets confused with steel it is a so dense. Hope to hear from you soon. Thanks again.
  #17
Old 03-04-2009
Creekmore 36s
J24mark: How did your Dad get the pictures up on this site? Also, I am trying to share them with the other partners in "Georgia." I have given them a link to our Creekmore exchanges. I am not sure they have been successful.
I want to get some photos of "Georgia" to the site. It looks like I need to set up an account on BucketPhoto, load my photos there, and then provide a URL address for readers here to use. It looks, though, like your Dad actually put his photos directly into this thread. Maybe I am not understanding how this works. Advise me as best you can. Scoopy.
  #18
Old 03-04-2009
There is a button next to post quick reply called "go advanced." Once you go advanced you can scroll down and it says Manage Attachments, from there a window will pop up. You simply find the picture files on your computer and attach them. If you need any more help just let me know.
  #19
Old 03-04-2009
Creekmore 36s
Here are some photos of the interior and exterior of "Georgia," a Creekmore 36.
The aft part of the main cabin house was raised to accomodate a raised dinette to port in the after part of the main cabin. As part of this customization when the boat was built, the cockpit was made about one foot shorter in order to gain more room in the main cabin. Two large windows on each side replaced the single port holes. The galley is to starboard, opposite the dinette. No mechanical refrigeration (ice). The main cabin has two berths as does the forward stateroom. The head is to port. The holding tank is under the port forward berth. A drop-down fold-out table has been added in the main cabin because the dinette really can't sit four people comfortably (shoulders bump into the side of the cabin house). The table can be dropped, turning the dinette into a double berth. She is steered with a wheel. The boom was shortened by several feet in order to reduce weather helm. She has a centerboard. She now has a Westerbeke/Universal M35B diesel engine. If there was a baby stay, there is no evidence of it now. She carries a roller furling genoa.
Let me know if you need additional explanations of the photos.
Scoopy.
  #20
Old 03-04-2009
J24mark and CreekmoreJohn: Here are some more photos of "Georgia." Scoopy
You may post attachments
You may edit your posts
Fischer Panda Owner''s Forum geoffschultz General Discussion (sailing related) 2 12-29-2003 10:16 PM
Fischer Panda Owner''s Forum geoffschultz Gear & Maintenance 2 10-01-2003 05:45 AM
Partner Owners rakowski Crew Wanted 1 09-17-2003 10:33 AM
350 Owners Association (Catalina) Bluesmoods Boat Review and Purchase Forum 2 12-31-2002 01:18 PM
Owners time Grenadines dale1122 Chartering 1 10-23-2002 06:01 AM
SEO by vBSEO 3.6.1
