Morgan 41 in freezing water - Page 2 - SailNet Community
post #11 of 22 Old 10-31-2010 Thread Starter
I understand the bubbler is bringing warmer water to surface but it's not also keeping water moving, preventing from freezing?
It's not a question of $$$, I would like to keep the boat close to my house, keep her longer in the water (yard are lifting boat early and putting them back late in spring) and tired to have to move/remove mast with boom truck (there is a power line to acces the yard)
+ there is a rapid waters (don't know how to call them in english) so I think water is freezing less deeply with below water current where I project to leave to boat.
Shacleton is old story, I saw a 41 from my eyes in deep freeze last winter: no damage, nothing...some aluminium ans steel boat can stay in freezing water, why not a heavily and thick Morgan 41 hull? I think that if something happen, it will lift the boat with the flat shape of the hull, the morgan I saw did not seem to have moved.
evasion is offline
post #12 of 22 Old 11-01-2010
Tartan 27' owner
CalebD's Avatar
Water with a lot of current (rapidly moving waters) will not freeze as readily as still water.
Good luck however you proceed.
Everybody has one:
CalebD is offline
post #13 of 22 Old 11-01-2010
I do not think its at all good for a boat to be locked in 3-4 feet of ice. However, I believe that the damage comes when the ice starts to move away as it breaks-up/thaws. Locked in ice is not good for the boat but will most likely not cause the real damage (unless seacocks freeze and burst). Docks and poles typically get damaged when the ice is pulled away. Now every situation is going to be different here so I am commenting based off general experience.
I use an ice-eater for my 30 footer in a salt-water creek in NY. Low-low tide the keel is at rest on very soft mud at my dock (~4 feet directly under the boat and maybe 6 foot several more feet away from the dock). The ice-eater works fine and no ice ever develops under these circumstances. It could be that its angled in a way to pull water from the center of the creek where its deeper and slightly warmer but again, no ice forms around my boat.
Every situation is going to be different but the above is my experience in cold-cold 20 degree winters.
- Rob
CatalinaRob is offline
post #14 of 22 Old 11-01-2010
MC1
No way I would let my fiberglass "significant investment" get locked in ice if I could prevent it. I've read of steel boats wintering-in this way much further north, but I think it's too risky with fiberglass. Our marina in Lake Ontario uses bubblers in a few places (to protect underwater electrical conduits coming up to the dock) to good affect with 6 - 8 foot water depths. Keeping the water moving appears to be the crucial thing. On a really really cold night, a thin surface coat of ice might still form, but each time I looked anyway, the bubblers had it broken up by noon. Even with bubblers, I'd still be nervous they'd stop (e.g., power loss) when I wasn't able to check on them.
MC1 is offline
post #15 of 22 Old 11-01-2010 Thread Starter
there is no tide where the boat will be and it's not salt water.
when ice thaws, it is expending then causing breakage?
For ice-build up (accumulation of ice), I noticed they were next to the shore, not at 100 feet of it.
Howewer I think I will get some kind of device the prevent ice, at least the first year and make some tests without the boat in the water.
Rob, I understand ice-eater is working for you in 4 feet of water. Is a ice-eater same thingh as a bubbler or it's different type?
evasion is offline
post #16 of 22 Old 11-01-2010
Memopad's Avatar
Last winter I watched the ice on lake superior drag a 1,000lb block of concrete about 1/4mile as the ice moved. Someone didn't sink their mooring, it froze in the ice and got drug. Kind of illustrates the power of what you're dealing with... and that was in a relatively protected harbour.
1978 Ranger 28 and a fleet of Mini 12's.
Ropes and rigging and splicing, oh my!
Memopad is offline
post #17 of 22 Old 11-01-2010
If you are in a river that does not freeze more than a few inches you will probably be fine. Your description on the boat you saw in 3-4 foot of ice said that it was pulled out in January. If the hull does not get crushed in that much ice I can assure you that the ice will move in the Spring, especially if there is a current. Windage alone will move ice which will then do major damage to anything in its way. I have seen steel boat lifts turned into pretzels by spring ice.
Good luck
tomandchris is offline
post #18 of 22 Old 11-01-2010 Thread Starter
This is a good point, the moving ice in the spring can be a problem for sure.
But I watched ice movement last year on the bassin and there was next to none.
Ice only melt in place or so with some weak movements that won't hurt the hull I'm sure (current is only underwater and I think there is one because a stream in line with the rapid de-ice faster every year.
The problem can be if I get strong winds from north (rare but it can happen), and all the ice from about 1 miles of the bassin go toward my boat that will be close to shore (at anchor on the south part of the bassin)
There must me a way the prevent ice from touching the hull like suspend pieces of 2x6 of wood next to fenders aroung the boat ?
Some water front home owners leave their docks in the water without problem everyyear at this place, maybe they were lucky...
keep giving me your advices :-)
evasion is offline
post #19 of 22 Old 11-01-2010
MC1
If the boat is insured, you may want to check with your insurance company beforehand to confirm the boat would be covered if it became locked in ice. Insurance companies usually frown upon owners knowingly leaving insured property at significant risk. In the event of a loss, use of the bubblers might be important to show you made a reasonable effort to protect the boat from damage. If self-insuring . . . one would have to be a brave soul indeed to let a fiberglass boat become engulfed in that much ice.
MC1 is offline
post #20 of 22 Old 11-02-2010 Thread Starter
insurance is certainly a concern your right, but I can assume the risk myself.
Ice is less present year to year, a friend of mine just bought a fiberglass amor 40 that made succesfully the north west passage last year and he is not the only one that made it in a plastic boat.
Sail-World.com : North West Passage Ahoy - seven yachts and counting...
Maybe I should change my question: what are the conditions the keep a plastic boat in the winter in Canada? A lot of people did it or doing it right now, I won't be the first, just want to know how to make it the right way.
So what I need? Bubblers, 360 degrees protection (I guest it's not all boat winterizing in the water that as that protection), heating inside the boat, 2x4 around the boat ???
I won't be liveaboard, my house is 2 minutes from the boat so I can keep an eye on it.
evasion is offline
freezing point of kerosene? e31 Gear & Maintenance 23 2 Weeks Ago 10:37 AM
Show us some sun. Were freezing! LindsayHerforth Introduce Yourself 8 02-24-2009 11:24 PM
Freezing temps tonight... should I panic ?? scottbr General Discussion (sailing related) 7 10-22-2008 06:22 AM
A/C freezing up wfahey Gear & Maintenance 10 04-14-2008 10:20 AM
Freezing Scuppers Quickstep192 Gear & Maintenance 3 04-02-2001 02:56 PM
