Mold & Mildew control - Page 2 - SailNet Community
post #11 of 29 Old 03-18-2011
ardoin's Avatar
For hard surfaces, clean with the old style Lysol (the brown bottle stuff that smells like iodine).
Cy
S/V Music
MASON 44
ardoin is offline
post #12 of 29 Old 03-19-2011
CaptainForce's Avatar
In order to maintain a mold and mildew free cabin after cleaning we have had great success with the product "Damp-Rid". It is not a product to leave hanging in the boat while occupying the space, but excellent to leave in the cabin while you are away. Take care and joy, Aythya crew
CaptainForce is offline
post #13 of 29 Old 03-19-2011
svjobeth's Avatar
Here in the southeast US, where 'low humidity' is in the 50% range, we battle this constantly. Dehumidifiers work reasonably well, but on a typically high humidity day, (or stretches of days) where it can be 80% or higher, it's been our experience there is no magic bullet.
We use chemical dehumidifiers (like Damprid) in the spring/summer months and change them out weekly. Other than that, we wipe the interior 3 or 4 times per year with a white vinegar/water bath. That seems to work well enough.
On a similar line of thought, what do people use to stop running rigging from going green? That is an ongoing battle for us. (If this is too far off topic, I'll re-post...thanks!)
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is offline
post #14 of 29 Old 03-19-2011
Mould Mildew
When you say "SE U.S." are you referring to as far down as the Miami area ?
I am from Canada, thinking to keep a boat in the Miami area as I travel here often enough to make reasonable use of it. However, because I may leave the boat for extended periods of time, I would like to know what to expect. More than likely, the boat would stay on a swing mooring.
Stickman is offline
post #15 of 29 Old 03-19-2011
svjobeth's Avatar
We lived in Miami for many years and are in Savannah, GA now. When I wrote my reply, it was with the GA /SC areas in mind. After some thought, I'd say the humidity is about the same when averaged out over the year.
The one difference is in south Florida, it's warmer longer. This may nurture unwanted things to grow. Here, we do get a few chilly weeks.
Bill & Lisa Ballard
S/V Jo Beth
- Mark Twain
svjobeth is offline
post #16 of 29 Old 03-20-2011
Swab
vega1860's Avatar
Coming late to this party but I may have something to add. Sailingdog pretty much covered it but I would like to emphasize that the only long-term solution is ventilation. Dehumidifiers are just band-aids that do not really address the problem. If you can find a copy of the now out of print "The Warm Dry Boat", snap it up. It has all the answers.
In a nutshell, you have to bring fresh air in, through and out of the boat while circulating it through every locker and space in the vessel. The intake vent should be as far as possible from the exhaust vent to allow complete circulation so that water vapor created by cooking, heating and crew respiration, and just high humidity, is carried out of the boat.
We have three passive mushroom intake vents aft, two of them just inches from the transom, one passive exhaust vent over the head, one four inch solar exhaust vent in the forward hatch and one four inch 12V, 2 speed exhaust vent right forward at the bow. There are circulating fans in two of the lockers and passive vents all around to allow interior circulation. Air flows into the cockpit lockers, through a vent into the cabin, through the lockers forward into the forward cabin and head, helped through the lockers under the forward bunk with a circulating fan, and is drawn out through the three exhaust vents forward.
We found we had to create an air space under our mattress and settee cushions to prevent them getting soaked and mildewed from condensation in cold weather. We found a product similar to a loose weave 3M scrubbing pad that goes under the cushions to allow air flow.
In cold humid weather we still get a little condensation in the forward cabin at night but it is not much of a problem. I am considering adding another solar vent.
Or just sailing back to Hawaii so we can leave the hatch open
Over the holidays we left our boat for a month with the solar vent in the forward hatch the only active vent, turning off all the circulating fans and the 12V exhaust vent forward. When we returned to the boat she was dry and sweet smelling so I guess we can say this system works for us.
The book I mentioned, if you can find it, gives formulas for how much air flow per crew member and size of boat. It also has a table showing how much water vapor is created by various types of heating and cooking fuels.
vega1860 is offline
post #17 of 29 Old 03-20-2011 Thread Starter
poopdeckpappy's Avatar
I have done most everything suggested except steamclean the cushions, which I'll do this week, I'll look for this book you mentioned.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #18 of 29 Old 03-20-2011
captflood's Avatar
Greetings Earthlings; Ive used Milton it a baby bottle steriliser this was recomended to my by a biulder who had a lot of expence trying to right this problem in a old cottage (1554) in Cheshire and the old Lady (87) next door says she used Milton and has kept the mold at bay for years and it worked in my bilges see similar porducts in local area.GO SAFE
captflood is offline
post #19 of 29 Old 03-21-2011
Crotchety Old Member
tomperanteau's Avatar
I have had this idea of buying cheap 12v computer cooling fans (around $6) and cutting out behind closets and cabinets so that I could circulate air out of them. Several of them go through to the bilge for obvious reasons, so with several of these in exits cut into the cabinets it would also ventilate the bilge nicely. Of course all has to be ultimately vented to the outside through the cabin.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
post #20 of 29 Old 03-21-2011
Originally Posted by tomperanteau View Post
I have had this idea of buying cheap 12v computer cooling fans......
I wonder how long they would stand up to the humidity and salt air.
Jeanneau 54DS
Minnewaska is offline
Black Mold gentryd Gear & Maintenance 27 07-29-2011 08:25 PM
mold inhibitors? dnf777 General Discussion (sailing related) 1 08-01-2010 10:54 AM
A smell of mold johnez General Discussion (sailing related) 1 08-20-2009 12:20 PM
Dealing with mold GaryHLucas Gear & Maintenance 3 06-11-2009 08:59 PM
Eliminate all mold and mildew with Bilgebuster? SailingAlien General Discussion (sailing related) 10 06-05-2009 12:07 PM
