Hot water - Page 5 - SailNet Community
 1Likes
post #41 of 47 Old 02-18-2012
Maine Sail's Avatar
Originally Posted by sea_hunter View Post
That's a good suggestion, but would kibosh the ESPAR idea and go with the Webasto version as Espar is known for poor reliability and support.
Espar poor reliability?? Not my experience at all.... Up here Espar parts are VERY easy to get though you rarely need them and support is easily available if needed. Both Webasto and Espar are decent units.
If you'd said Espar is more expensive then I could agree but not on the reliability statement...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #42 of 47 Old 02-19-2012
Mermaid Hunter
SVAuspicious's Avatar
I have owned and run both Webasto and Espar on my liveaboard boat. My experience has been that Espar is much more reliable and maintenance is easier.
SVAuspicious is offline
post #43 of 47 Old 02-19-2012
Maine Sail's Avatar
Having worked on both, that is also my take... I have a number of customers who've owned both brands on different boats. Most have preferred the Espar to the Webasto.. . But again, both brands make a decent product and both are quite reliable...
______
post #44 of 47 Old 03-05-2012
Re: Hot water
Interested to hear any input on this, as this is what we're planning to do...
Originally Posted by MSter View Post
This may be a small tangent, but, another point to consider is the use of a diversion load from a solar/wind charge controller. This diversion load circuit can include a 12v heating element installed in the hot water tank in place of the 110v element. Once the charge controller satisfies the battery banks, it diverts usable voltage to the diversion load. This is something I am considering but have not yet tried or even fully investigated. How efficient is this (no idea)???....but it does seem logical not to waste the electrical potential when available.
wouldrathersail is offline
post #45 of 47 Old 03-05-2012
Amazing Grace's Avatar
Re: Hot water
Hot water on demand via LPG hot water heater. Runs directly off propane. Much more efficient than heat exchanger. Works on same principal as at home on demand LPG hot water heater. :-)
Amazing Grace is offline
post #46 of 47 Old 03-05-2012
Senior Cruiser
sea_hunter's Avatar
Re: Hot water
Tankless propane water heaters are not recommended for boats unless externally mounted. (Read manufacturers' instruction manuals) The other issue is tankless water heaters burn exorbitant amounts of NG or propane (Figure out the BTU's~ input to output) and are little better than generator powered electric versions. It's all in the math (or the fuel). In the end, diesel hot water heaters are the safest and most efficient.
sea_hunter is offline
post #47 of 47 Old 03-05-2012
Senior Cruiser
sea_hunter's Avatar
Re: Hot water
I've installed this diversionary system and it does work, but is dependent on the ability of the charge controller. The Outback has a very reasonable interface that's user friendly and easy to hook up. The element issue is neither here nor there as an element is merely a resistor and doesn't care about voltage (it's about cycling and amps). A small 2 gallon electric (110 or 220V) hot water tank (from your local home hardware store) with the diverted load wired through the thermostat works just fine. The only problem is when you're creating a large amount of diverted heat; you'll need a cold water mixing valve to prevent scalding.
Air, Water or Air / Water Cooled Refer Condensor OceanFreedom Gear & Maintenance 12 02-03-2011 12:35 AM
Fresh Water cooling water dirty brown sailak Gear & Maintenance 17 07-31-2009 11:52 PM
Refrigeration -Using the water tank as a cooling water source HenryRusty Gear & Maintenance 7 03-29-2007 12:14 AM
Fresh water boat to salt water svs3 Boat Review and Purchase Forum 6 12-30-2006 12:41 PM
MD3B Volvo-Penta sea water to fresh water conversion slosharron Gear & Maintenance 20 06-17-2003 09:08 PM
