Go Back   SailNet Community > General Interest Forums > Cruising & Liveaboard Forum > Living Aboard
Like Tree3Likes
  #1
Old 10-26-2012
Hopefulliveaboard is on a distinguished road
Self sufficent energy
Would like to have plenty of power using solar and wind and invertors both sine wave and modified, any suggestions as to a functual setup?
  #2
Old 10-26-2012
Capnblu's Avatar
Capnblu is on a distinguished road
Re: Self sufficent energy
Your price range will probably determine your setup. Also, what is plenty of power? What do you wish to run off of this setup? What does it have to be stuffed into, and mounted onto? I have Magnum components, 10 trojan t105's, balmar 200 amp alternator, etc.
Why, why, why?
I Don't Know! I Don't Know!
  #3
Old 10-26-2012
Hmm is it doable with 10grand for the power systems and I was thinking a 35 to 40 ft cruiser vessel
  #4
Old 10-26-2012
Can you ballpark for a fridge, computer,lights,heater,ac,waterheater, phone charger, tv dvd, and any pumps that need to run?
  #5
Old 10-26-2012
Not enough cash? 15k?
  #6
Old 10-26-2012
Is there a marine motor that can replace a diesel engine that runs from sustainable power? Or a hybrid engine of some type? Also which are the best deep cycle batteries for a large bank?
  #7
Old 10-26-2012
20k ? Ive found several sites for juicing up rv's and vans but not so much for sailboats any good links or sites?
  #8
Old 10-26-2012
Stumble is on a distinguished road
Oh god the hybrid thing again...
You really need to figure out your energy budget. The only way to do that is to figure out what equipment you will be using, how much you will be using it, and then add up the numbers. There are tools all over the Internet that will help you.
As for electric power to replace a diesel. Do a forum search, but generally no. You can't carry enough batteries to replace the diesel tanks, or anywhere close. If all you will ever do is drive off the dock, then you might be able to.
As for budget, 10-15,000 would be a minimum to seriously consider this, and that would require pretty spartan living in an area near the equator, with a minimal number of cloudy days.
Greg Rubin
Titanium Salesman
  #9
Old 10-26-2012
Thank you
  #10
Old 10-26-2012
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
In the Caribbean somewhere between 300 and 400 watts of tiltable solar will cover the above EXCEPT the waterheater.
A solar shower or two will give you hot water on a sunny day and warm water on a cloudy one.
Tags
cruising , liveaboard , power
You may post attachments
You may edit your posts
YOG energy knothead General Discussion (sailing related) 0 09-27-2010 06:17 PM
Earth 4 Energy- Has anyone tried this? Freerider Living Aboard 33 05-20-2009 10:25 AM
SEO by vBSEO 3.6.1
