This video is absolutely riveting... - SailNet Community
 2Likes
  • 2 Post By ccriders
post #1 of 9 Old 07-26-2014 Thread Starter
Senior Smart Aleck
jameswilson29's Avatar
Replacing old corroded rivets on spinnaker pole with new rivets:
jameswilson29 is offline
post #2 of 9 Old 07-26-2014
Re: This video is absolutely riveting...
That is the best demonstration for why you should use rivets in lieu of stainless screws. Just the time cursing would have been longer than the whole rivet process took.
John
jameswilson29 and Group9 like this.
ccriders is offline
post #3 of 9 Old 07-27-2014 Thread Starter
Senior Smart Aleck
Yes, I replaced 6 rivets in less than 10 minutes. Both ends are now tightened up, after becoming quite loose. The forces are spinnaker pole ends are shearing forces, so a rivet is perfectly well-suited to the task.
post #4 of 9 Old 07-27-2014
MarkofSeaLife's Avatar
Dock
Very good James.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
jameswilson29 (07-27-2014)
post #5 of 9 Old 07-29-2014
For the newbies if using stainless steel rivets in an aluminum pole be sure to coat the rivets with tef-gel or something similar to prevent galvanic corrosion.
kentobin is offline
post #6 of 9 Old 07-29-2014
Group9's Avatar
Rivets are great.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #7 of 9 Old 03-05-2015
rivet shear strength
Are you aware of published info on shear strength of stainless or aluminum (?) Rivets in aluminum spars?
wbjr is offline
post #8 of 9 Old 05-04-2015
thx for sharing
stardust is offline
post #9 of 9 Old 05-04-2015
I don't discuss my member
zz4gta's Avatar
The pole itself is usually in compression, not shear. The way the pole is fitted to the ends, there should be little load on rivets themselves.
Merit 25 # 764 "Audrey"
zz4gta is offline
Absolutely confused Schmacko Cruising & Liveaboard Forum 4 09-15-2009 06:56 AM
I know absolutely nothing about sailing southwindphoto Introduce Yourself 12 09-07-2009 10:04 AM
Riveting? How does this work? dsimon1044 Gear & Maintenance 13 07-01-2009 07:37 PM
Absolutely Everybody JohnRPollard General Discussion (sailing related) 13 09-14-2007 03:32 PM
Rivets - removal, riveting, tools, etc tenuki Gear & Maintenance 18 06-03-2007 08:19 PM
HTML code is Off
