Business is picking up and it looks like I won't have much time to work on my boat, so I need to get help for some of my winter projects. My 1992 Hunter Vision 32 is on the hard at Admiral's Hill in Chelsea, MA.
I need someone to replace the cutlass bearing, prop shaft, shaft seal & engine mounts. I also need someone to add a vented loop to the bilge discharge. Any recommendations for vendors would be appreciated.
"The bilge pump discharges through the starboard side hull in the midships area, and does not employ an anti-syphon valve to prevent backflow. There is a check valve, which may be used, but only for convenience and not as a primary means of preventing backflow or syphoning from overboard. It is recommended that a proper anti-syphon valve be installed as close to the deck as possible above the pump outlet."
The insurance company requires me to implement the surveyor's recommendations.
Related Threads
1.7M posts
173.8K members
Since 1990
