How do you feel about catamarans? - Page 31 - SailNet Community
 125Likes
post #301 of 308 Old 07-07-2014
Full-time Liveaboard
CaptainChaos's Avatar
Re: How do you feel about catamarans?
Don't forget the faster boat has a different apparent wind and this can often create the effect that it is not pointing when in fact it is pointing just a high as the mono but with a different apparent wind AWA relative to the slower boat.
There are some cats that point very well.
There are some cats that are pigs upwind.
I treat them all individually.
Bob, I definitely agree with your comments about apparent wind.
Going in an orthogonal direction, though, wouldn't you agree the reason many people buy cruising cats necessitates sacrifices that affect performance?
For example, many people like cats because of the shallower draft but that means they don't have enough keel for windward work. Secondly, cats are fastest when they're lightly loaded but the average cruiser puts in so much gear/equipment the hulls have too much drag so the wetted surface area of the too (typically large) hulls is huge.
bobperry likes this.
Walt
s/v Wanderlust
Passport 545
CaptainChaos is offline
post #302 of 308 Old 07-08-2014
pdqaltair's Avatar
a. If I refer to a course relative to wind, I always mean true wind. If someone has a point to make where relative wind is particularly relevant (spinnaker set) they should make that point separately. This convention just seems more clear to me. As we all know, a beach cat or fast skiff is as "close hauled" on a reach as many slow boats.
b. As for why many cats are pigs, there are many reasons:
1. Under canvassed. Many charter designs do this since they don't know the crew or the sailing area. They want to make them stupid-proof. While a mono-hull will tell you in simple terms when over canvassed, the obvious symptoms for a multi-hull occur too late.
2. Lotsa of room for junk. If you don't want to stay light, sail a mono-hull. Although I have a tender on davits, you will find many lockers are empty. I don't haul what I don't need. I have a good tool kit and required spares.
3. Poor feel. Cruising cats are more by the numbers ad what you see, than what you feel, particularly when wheel-steered. My boat has very little helm feel or motion/lean feel until the wind hits 12 knots and boats speed over 7 knots. Then it comes alive and is quite pleasant. But even then the feel is very light, which might bother some day sailing and make fast trim and steering tricky. On the other hand, it makes long passages easy. But the point is that feel is less, not absent. An experience cat sailor gets in tune and works the puffs and waves without the need for much feel.
4. Draft and keel. Yup, draft helps. But I don't think it is the major factor. Any sailor that learned on small cats knows that short (or none) keels stall easily and that you must retain the right balance of speed and side load. I think this is a feel that cat sailors must be more aware of than monohull sailors. It is why pinching just a few degrees is fatal... and yet with the right balance I can tack through 90 degrees, though 100 degrees is generally better VMG in chop, for me.
In the prior story, for what it is worth, the up wind leg required at least 2 tacks through a slot; VMG was the thing that mattered. No cheating by footing. Same down wind, since we are all bound to the same marina. Point to point, windward/leeward.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #303 of 308 Old 10-27-2014
Smile Re: How do you feel about catamarans?
Originally Posted by Solon View Post
What does everyone think about catamaran sailboats? I have not seen any post about them. Are they harder to sail? Are they safer in off shores sailing?
This link will take you to the thread that was posted - started July 2012
CATAMARAN DESIGN and BRIDEDECK CLEARANCE
Cheers:
cyclone warnings for the south pacific Cyclone season 2014 to 2015 and sever extreme weather happenings warnings. Perfect Cyclone Storms l
piclarke is offline
post #304 of 308 Old 01-08-2015
Boring like a condo. Except for the sinking problem: 3 dead in tourist catamaran wreck off Costa Rica - The Washington Post
Here we go!
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #305 of 308 Old 01-08-2015
Minnesail's Avatar
Here we go!
That's a very odd looking sailboat:
Catalina 22
on a starboard tack
Minnesail is online now
post #306 of 308 Old 01-08-2015
smj
[QUOTE=aloof;2486633]Boring like a condo. Except for the sinking problem: 3 dead in tourist catamaran wreck off Costa Rica - The Washington Post
Here we go![/
You really need to educate yourself
smj is offline
post #307 of 308 Old 01-09-2015
I assume this was just a teasing poke in the eye.
captain jack likes this.
Jeanneau 54DS
Minnewaska is offline
post #308 of 308 Old 01-10-2015
Senior Pirate
TropicCat's Avatar
Nah - Those are fightin words....
Tropic Cat
TropicCat is offline
Most of you know how I feel about waving, right? flyingwelshman General Discussion (sailing related) 32 08-19-2013 10:46 PM
Help I feel out of my depth rwilson37643 Boat Review and Purchase Forum 44 02-12-2012 12:21 PM
Does anyone ever feel this way? Barquito General Discussion (sailing related) 43 10-10-2010 12:32 PM
HTML code is Off
