How do you feel about catamarans? - Page 5 - SailNet Community
 125Likes
post #41 of 308 Old 02-26-2014
FSMike's Avatar
Re: How do you feel about catamarans?
Originally Posted by capt vimes View Post
and now show me a boat that stays afloat for long if holed...
capt vimes -
Let's have an experiment. You drill a hole in the bottom of your boat and I'll drill a hole in the bottom of mine, and we'll go sailing.
No patching or pumping allowed.
Click on my avatar for boat pictures.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #42 of 308 Old 02-26-2014
Life is a wild ride!
Dean101's Avatar
This article seems to be fairly unbiased. I enjoyed reading anyway.
The Ten Commandments of Buying a Catamaran
zedboy likes this.
Dean101 is offline
post #43 of 308 Old 02-26-2014
Well apart from having a great area to live in, the shallow draft to go lots of places and the fact that you could leave your glass of wine on the table while sailing because they don't hill, I don't quite like Cats.
The hilling capacity of a sail boat it's what lets you know right away the wind picked up and you have to take a reef. If you are cruising around at full sail and you get hit by a squall, your mono hull will hill right away letting you know you have to reduce the sail area immediately. Instead a Cat wont hill as easy, because they are so wide, putting a lot of pressure on your rigging. The reefing on a Cat it's done by the book, so you have to be very aware of the reefing wind characteristics of your cat, for example if the wind strength hits 18knts on your instruments you might not feel a thing but you have to take the first reef, if if hits 25knts take 2d and so on. The problem with this is that some times you might not feel the wind speed changes until it's a little too late and this could jeopardize your rigging. Another thing is the bouncing back and forth and side ways going though the waves. One hull is hit by one wave and the other is hit by a different one pounding the hell out of the hulls.
Another disadvantage on a Cat is your sailing window. On a regular mono hull you can pretty much sail from 30 degrees in to the wind down to practically death down wind. On a Cat you might go up to 45 degrees and 120 down wind, if you do no want it to stop in your tracks and bounce back and forth like a cork.
Then there are minor things like the docking space can be very expensive because of the width and the lack of visibility while doing it.
But don't get me wrong there is nothing like trowing a party on a Cat when you are anchored.
capt vimes likes this.
ramonex1 is offline
post #44 of 308 Old 02-26-2014
Some years ago while sailing Mexico, we were out in 40 + Knts doing fine. There was a large Cat out at the same time. They had lots of trouble pointing, and the wind keep pushing them broadside to the waves. I've seen this happen several times to Cat's of different size. Say what you want I'll stick with sailing Mono hull boats, and party with the Cat's.
capt vimes and Solon like this.
Quote: The wind and waver are always on the side of the ablest navigator.-Edward Gibbon, "The Decline and Fall of the Roman Empire"
luck66 is offline
post #45 of 308 Old 02-26-2014
I have never sailed on a cat so have no firsthand knowledge. The problem I have with them is, they are so damn ugly to me. when I pull into a marina and there is a cat docked there it is the ugliest boat in the marina. I cant get past the looks to even think of owning one. I hope I don't offend any one, remember this is only my opinion based on what I think looks good.
mitchbrown is offline
post #46 of 308 Old 02-26-2014
smj
How much catamaran sailing experience do you have?
smj is offline
post #47 of 308 Old 02-26-2014
Originally Posted by pdqaltair View Post
Why the sarcastic response?
First, I apologize. Some post simple questions simply to generate noise. If you are simply curious, I was wrong. However, philisophically, there is a LOT of postings on this subject; I always search before I ask.
But the reason for my irritation is that this sort of question ALWAYS leads to a flurry of sailors that know NOTHING about catamarans giving silly, uninformed opinions. It's just tiresom. Some of the posts were from expereinced folks--I'm not talking about you.
The best answer, particularly if you have limited sailing experiece, is to sail many boats. Likes and dislikes are very personal. I enjoy many boats, both mono and multi.
You mean you don't have to put the helm over on Tuesday in order to tack by Thursday?? ;-)
nolatom is offline
post #48 of 308 Old 02-27-2014
Moody 46
It really is disappointing that so many take such a question as a cause or mission to bash a type of boat, especially so in that few have any real experience. Over the past 6 years I sailed my Moody 46 mono some 28,000nm and then my Lagoon 440 some 15,000nm to date.
All sailboats as we know come with pros and cons, and all have advantages in some conditions over another. It all depends on where you are sailing and perhaps budget. You will meet very few full-time cruisers that would go back to a mono but much of that is the comfort for full-time living and ease of movement on deck. One is not safer than another in real terms, although cats are statistically a bit safer. It's more about being a good sailor.
The whole pointing issue is overdone as well since if the cat is sailed well one can go down 10 degrees and still match or exceed the VMG of the higher pointing mono, assuming you are comparing a cruising cat to a cruising mono.
I like them both, I have chose to go cat for now but would not have an issue going back to a good mono, especially in say the Med where marina costs are so high. Also on long passage with short period seas like the Pacific I prefer the motion on a cruising mono over the jerky motion of the cat but upon reaching our destination - the cat for sure
captain jack likes this.
orthomartin is offline
post #49 of 308 Old 03-01-2014
When I answered the original question about Cats, I did it from a sailing point of view, I know some people get very personal about it if you bad mouth their Cats, but when I go sailing that's exactly what I want to do "sail".
Don't get me wrong I started sailing Hobie Cats for many years, when I was a teen. I had a 14, 16, and a 21 footer and I really enjoyed them, you know why? because they can go on one hull up to 20knts and your adrenalin too. That's what I love about Cats. Now, I get that same feeling going close hauled on a mono hull steering on the leeward side with your leeward reel in the water and looking at the sails with a perfect shape.
Sorry I can't get this with a cruising Cat.
ramonex1 is offline
post #50 of 308 Old 03-01-2014
norahs arc's Avatar
I learned to sail on a small cat. It turned out to be my first and last multihull.
I would not go further from land than I can swim in any boat that has an escape hatch in the bottom.
I joke about them with a son-in-law calling them catastoramans.
Catalina 27 Aft. galley, dinnet L/O
Update - Sold Norah's Ark Buying A 24'Shark
Saint John NB
Canada
norahs arc is offline
Most of you know how I feel about waving, right? flyingwelshman General Discussion (sailing related) 32 08-19-2013 11:46 PM
Help I feel out of my depth rwilson37643 Boat Review and Purchase Forum 44 02-12-2012 01:21 PM
Does anyone ever feel this way? Barquito General Discussion (sailing related) 43 10-10-2010 01:32 PM
HTML code is Off
