Yanmar Tranny - SailNet Community
LinkBack Article Tools
Old
Yanmar Tranny
by Larry D 07-05-2012
New here, new to sailing, and diesel power
Yanmar YSB12. If anyone is familiar with the drive on this unit, and can tell me if it should be very difficult to shift, I would appreciate it. Also, does it take regular tranny fluid?
Are the reverse/forward throws short?
It took my foot to push it into forward, and a lot of strength to pull it back to reverse.
Thanks for your help,
Larry
Reply With Quote Quick reply to this message
Share with Facebook
Views 835 Comments 5
Total Comments 5
Comments
Old 07-05-2012
Re: Yanmar Tranny
Does your throttle have a trigger to pull below the ball on the throttle. On my boat there is a little thing you need to squeeze to allow it to pop of of neutral. It also prevents you from throwing it into reverse when you back down to neutral.
If that is not the case I would look at the way your cables are run to make sure they are clear of obstructions and grease them while your there.
mm2187 is offline
Old 07-05-2012 Thread Starter
Re: Yanmar Tranny
Cables are OK, no squeeze ball. Where it is stiff is in the tranny itself. The level that actually moves the gears after the cable pushes it. I can push the shift lever, but it is very hard.
Thanks for your reply.
Larry D is offline
Old 07-08-2012
Re: Yanmar Tranny
the shifting lever at the gearbox is quite stiff,if you disconect the cable try moving it [on mine i can't shift it by hand only] the lever is too short!the leverege advantage is gained at the other end where the cable attaches to the shift handle and the handle its self,make sure the cable isn't binding enroute,the gearbox uses the same oil as your engine
sawingknots is offline
Old 07-08-2012 Thread Starter
Re: Yanmar Tranny
Thanks. That is exactly what I needed to know. I get a long throw into drive, but short throw to reverse. I guess it needs a little adjustment.
Larry D is offline
Old 07-08-2012
Re: Yanmar Tranny
that would be my guess,make sure the cable is routed in the in the loose's way possible,a little thin oil down into the end might not hurt either also you might take apart the shifter mechanism at the cockpit and lube that,mine is dificult to shift too
Tags
help...yanmar drive
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Article Tools
Similar Articles
Article Author Forum Replies Last Post
Installing tranny on Yanmar 2ym15 ... should I? lawsonmitchell Diesel 1 02-21-2012 02:13 PM
Looking for a tranny for 4-107-4-108 evasion Diesel 1 07-24-2010 08:46 AM
Yanmar tranny clunks on engagement jarod Diesel 5 03-28-2010 08:19 PM
Yanmar 2gm Tranny separation help!! jackmace Gear & Maintenance 3 03-09-2008 07:50 AM
Yanmar 2gm Tranny separation help!! jackmace Gear & Maintenance 0 02-18-2008 11:19 PM
