Spirit 23 keel cable conduit blocked - Page 2 - SailNet Community
post #11 of 17 Old 09-13-2013
formerly 'BoatyardBoy'
SailRedemption's Avatar
Re: Spirit 23 keel cable conduit blocked
Not only that but the CB keeps you point straight and not letting the wind push you diagonally because you have nothing underwater to keep you in a straight line minus the rudder. I wouldnt sail mine without it down. it doesn't sail straight, (see: crabbing or sailing diagonally)
SailRedemption is offline
post #12 of 17 Old 09-13-2013 Thread Starter
My understanding about this boat is that there is 1000 lbs. of lead ballast in the shoal keel the centerboard swings into. So even without the board I should still have most of the stability. So there is no safety issue. The only problem I see is not being able to point to the wind as well. The shoal keel looks substantial enough to prevent most of the crabbing.
I managed to snake a wire through the cable tubing but still have a piece of broken cable stuck at the end, still giving it a chance to unclog before installing new tubing.
A new problem I found, and glad I found, is the cockpit drain flexible tubing that drains to the back thru-hull fittings deteriorated to the point I could poke my finger into it. The hose clamps have rusted off the upper connection and the lower can't be removed because of rust. The thru hull fitting don't look great so I will replace them as well as the tubing. IT is not complicated just difficult to access. This could have sunk me. Although this boat does have positive buoyancy as I discovered in the hurricanes of 2004 when another boat adrift put a hole in mine. I was able to bring back up by bailing with a 5 gallon bucket all day.
riverspirit is offline
post #13 of 17 Old 09-13-2013
blobaugh's Avatar
The cockpit drain tubes are a common point of failure on these boats. Definitely something good to keep in mind during your inspections.
blobaugh is offline
The Following User Says Thank You to blobaugh For This Useful Post:
riverspirit (09-14-2013)
post #14 of 17 Old 09-14-2013
I wouldn't be too confident in upwind without the cb.. It's hardly a shoal keel. It slides more than you think. Before I fixed my cable, the cb was up when I sailed it to my boatyard, it had to stop because it wouldn't go straight. Had to just use the outboard. It really doesn't point at all with it up.
Sent from my Galaxy Nexus using Tapatalk 2
The Following User Says Thank You to SailRedemption For This Useful Post:
post #15 of 17 Old 09-14-2013 Thread Starter
Having some trouble with the cockpit drain tubing. The corrugated flexible tubing I found comes in one foot sections with a smooth part every foot to cut for a fitting connection. The length I need is a few inches more than the foot section and two feet is too long. The clear kind of flexible tubing that can be cut to any length fits but the bend below the cockpit causes it to kink. I'm thinking of adding a coupling to join the two different tubes. Anyone run into this situation or have a suggestion? Thanks.
post #16 of 17 Old 09-15-2013
blobaugh's Avatar
You should be able to use any of the standard flexible plumbing you can find at a hardware store. Talk to the plumbing department.
blobaugh is offline
post #17 of 17 Old 09-22-2013
my boat looks like the cockpit drain tubes are car radaiator hoses
southern cross
ct-34
Southron Spirit is offline
Spirit 23 Swing Keel Cable Mod Dwg windyway North American Yachts 18 07-04-2013 03:35 AM
Spirit keel removal sailor2800 SailNet FAQ 5 02-10-2013 03:06 PM
Best way to attach keel cable? JMN412 Gear & Maintenance 7 01-24-2013 02:36 PM
Bilge Pump for 23ft swing keel American Spirit thomasward00 General Discussion (sailing related) 2 10-06-2011 05:24 AM
Keel Cable/Tow/NavigationLoss VTNismoZ Gear & Maintenance 1 06-20-2005 02:32 PM
HTML code is Off
