Spirit 23 keel cable conduit blocked - SailNet Community
post #1 of 17 Old 09-07-2013 Thread Starter
I'm restoring a North American Yacht Spirit 23 and the conduit pipe for the swing keel cable is blocked near the exit, looks like there may be a piece of cable stuck in there. It was moored in saltwater and unused for a while so probably corroded. I cant push through the block with a snake and I cant pull it out from underneath up in the trunk. Does anyone have suggestions to unblock? I'm thinking about installing a new conduit or cutting the conduit at the access in the cabin floor near the blockage to unblock and reconnecting with a coupling. The conduit seems to be metal in a thick plastic coating.
If I were to choose between leaving the swing keel down or up, which would be best? There are a lot of shoal areas around but enough room to sail in the deeper water here in east central Florida. I will not be trailering.
riverspirit is offline
post #2 of 17 Old 09-08-2013
formerly 'BoatyardBoy'
SailRedemption's Avatar
Re: Spirit 23 keel cable conduit blocked
Just cut that old crap out and get some new ss tubing and make a new one like I did.. And fiberglass that in and a new ss cable and be done with it. I don't have any water problems, bilge is dry.
Sent from my Galaxy Nexus using Tapatalk 2
uploadfromtaptalk1378640307188.jpg   uploadfromtaptalk1378640328071.jpg   uploadfromtaptalk1378640354831.jpg   uploadfromtaptalk1378640374333.jpg
SailRedemption is offline
The Following User Says Thank You to SailRedemption For This Useful Post:
riverspirit (09-14-2013)
post #3 of 17 Old 09-08-2013
Side note, these are centreboard not swing keels so they have no weigh the to them, in fact I have a line tied to the bottom of the cb to pull it towards the bow(down) cause it won't do it on its own. I'll pick it up one day and drill a hole in the side of the cb and pour lead shot in it and cover it with resin. Fix that up real quick.
post #4 of 17 Old 09-08-2013
And a pic of the bilge after I was done.
post #5 of 17 Old 09-08-2013 Thread Starter
Thanks. My tubing enters from the side of the pocket in the trunk.
So you cut out the pocket and changed the tubing entry to the top?
Did you change the entry direction to avoid the chronic broken cables?
Why did you cut out the whole raised pocket, was that to give room under the floor to make the bend before entering the trunk?
What is in photo number three?
post #6 of 17 Old 09-08-2013 Thread Starter
Is there a fitting or anything on the end of the SS tubing?
post #7 of 17 Old 09-09-2013
Yea mine was like that too, terrible design. Makes the cable have to bend down which can put more wear on tubing and cable. Yea I cut it out completely and started fresh. Bent my tubing that way it would run into the seat storage area.
I went from the top so the cable would be directly over the CB and it would reduce stress on the pipe and the CB. Cut it put because I had to cut out the old pipe and I guess was a pulley but it was a bug rusted block. That and with a side grinder, that was the best cuts I could make with the limited space. 3rd photo is the tubing ran through the port seat storage area, I fiberglass it down so when crap was thrown in there it wouldn't mess with the pipe. Also, it keeps the pipe from Moving which will keep the 90* bend from getting stressed and leak.
No fitting or anything, I think I flared the tubing end. Also, when I attached the cable to the CB I put the bracket on the CB directly under the pipe end so there isn't any unnecessary stress when picking up the CB into the trunk.
post #8 of 17 Old 09-09-2013
blobaugh's Avatar
I cut the old stuff out of mine when I had it out last. Put in a new plastic tub to relieve the strain. Unfortunately I did not take any pics of it.
I did not go to the extremes of BoatyardBoy and I have not had any issues, though BoatyardBoy's solution is probably better for the cable in the long run.
blobaugh is offline
post #9 of 17 Old 09-12-2013
i have been sailing mine for over a year with no swing keel installed
if you store your boat on a trailer be sure and read the posts about what happens when the keel is down and gets hung up in the trailer
southern cross
ct-34
Southron Spirit is offline
post #10 of 17 Old 09-12-2013
blobaugh's Avatar
Be careful doing this. The swing keel helps to stabilize your boat when you are going upwind. It provides righting motion. Without it there (or down) your boat will be much tippier and unstable in high winds.
That said, I did not have a swing keel at all on Zippey for the first year I owned her and did not even realize it. The previous owner told me the swing keel was locked down. Ben Lobaugh Online ZDD: Lucky sailing this summer
blobaugh is offline
Spirit 23 Swing Keel Cable Mod Dwg windyway North American Yachts 18 07-04-2013 03:35 AM
Spirit keel removal sailor2800 SailNet FAQ 5 02-10-2013 03:06 PM
Best way to attach keel cable? JMN412 Gear & Maintenance 7 01-24-2013 02:36 PM
Bilge Pump for 23ft swing keel American Spirit thomasward00 General Discussion (sailing related) 2 10-06-2011 05:24 AM
Keel Cable/Tow/NavigationLoss VTNismoZ Gear & Maintenance 1 06-20-2005 02:32 PM
HTML code is Off
