New (to me) Spirit 23k - Page 2 - SailNet Community
post #11 of 20 Old 12-20-2016
twoshoes's Avatar
Re: New (to me) Spirit 23k
Hello WolfmanBob,
The Neuse is our sailing ground. Would that be Duck Creek you've got your boat at in those pics? Had our boat hauled and painted there last winter. We keep the boat at the New Bern Grand and try to get down there every weekend we can during Spring, Summer, and Fall. I'll keep an eye out for you when the weather warms up.
twoshoes is offline
post #12 of 20 Old 12-20-2016 Thread Starter
It was at Duck Creek. What a great place for DIY'ers. The people there were very nice and the price is reasonable.
I keep my boat at a friend's dock in Fairfield Harbor but will probably move to Matthews Point this spring. I'll be looking for you too. What's your boat name?
WolfmanBob is offline
post #13 of 20 Old 12-20-2016
twoshoes's Avatar
I'm somewhat familiar with Matthew's Point, our 104 class sailed out of there. A decent little marina, but not too much else in the area, which is fine if you like things quiet.
Our money-pit is called Cal A Lily, a 1981 Cal 2-25. I use a profile drawing of one as my sig.
twoshoes is offline
post #14 of 20 Old 12-21-2016 Thread Starter
Agreed, twoshoes, the area is lacking in amenities. But I live in Morehead City and Matthews Point is much closer to home.
I'll keep my eyes open for you.
post #15 of 20 Old 12-22-2016
blobaugh's Avatar
WolfmanBob- I had a random flash of something this evening that made me come look at your pics again. It does not look like you have a boom vang. Zippey did not either. Sailed her for years without one (and frankly did not know what they did!). After I started racing on other peoples boats I quickly realized the value of a vang and added one to Zippey. I also added a cunningham (main downhaul) because I could not get the halyard tight enough. The difference in performance was astounding! She points much better upwind now and her mainsail shape is a ton better. If I add a traveler I am confident she will point even higher and I will be able to keep (nearly) with my buddy's Cal 24.
This image is stolen from a Google Image search, but it is essentially what I did
Surprisingly you can get the fiddle blocks for this cheaper than anywhere else! They are good blocks too if you do not need high performance racing blocks.
Fiddle with becket and cam cleat $58 LEWMAR 50mm Synchro Fiddle Block with Becket and Cam | West Marine
Fiddle $32 LEWMAR 50mm Synchro Fiddle Block | West Marine
I used 3/8 line on it just fine.
The entire vang setup can be had for less than $100 if you do not go high performance, which these boats really do not need.
If you are curious I designed a traveler system with an engineer buddy who has been racing for 31 years quite successfully. The goal was to build something as cheaply as possible that would require the least amount of modification to the boat. It has not been implemented yet. What I wound up with is a line based system that uses a single continuous line and can be attached to the transom cleats. It can be quickly disconnected and the traditional inverted V hooked back up also. Here is a link to my design and write up about it https://www.evernote.com/l/Ae2TxuBul...y9xGRA88XoWcIQ.
blobaugh is offline
post #16 of 20 Old 12-22-2016 Thread Starter
Wow, thanks for the info, blogaugh. The timing is ironic because the guy I bought the boat from and I are both engineers and we were just discussing how to set up a boom vang and a traveler very similar to what you showed. We like your design better and he's planning to implement it on one of his boats as well. I'll let you know how it goes.
I really appreciate you sharing that info with me.
post #17 of 20 Old 12-22-2016 Thread Starter
Sorry, blobaugh not blogaugh.
post #18 of 20 Old 12-22-2016
blobaugh's Avatar
Hehe, no problem!
Def report back on how it works out for you. I have not implemented it yet myself. If you get to it first I would love to know your experience.
blobaugh is offline
post #19 of 20 Old 2 Weeks Ago
blobaugh's Avatar
WolfmanBob did you ever try out that traveler setup?
Another thought just hit me, from the the new Beneteaus that were at the Seattle boat show. They have an arch over the cockpit that has two connection points on it about 45 degrees off the centered boom. No traveler. This supposedly allows you to get the same results as a traveler. Eliminates a lot of possible failure points, extra lines, and a traveler in the way somewhere to manage. For cruising I can see it being effective, for racing it might work but I would want the connection points further out.
Anyways, you could potentially run a system like this of the existing inverted V connection points. It may be what the designer was originally going for actually but having the mainsheet above the point of the V seems to have ruined the usefulness.
Beneteau has a page devoted to this system Mainsail arch | Beneteau
Here is a pic of it. Note the single solid connection on the boom. From there it runs up and down to create its V, and then up to the front. That last part could be changed, otherwise it might be worth trying.
blobaugh is offline
post #20 of 20 Old 1 Week Ago Thread Starter
No, blobaugh, I haven't done anything with the traveler yet. That setup is interesting. It certainly seems simpler.
Spirit 6.5 silverado North American Yachts 8 11-09-2015 11:58 PM
Companion Way Sliding Hatch Mold For Spirit 21' & Hatch For Spirit 23' For Sale tomsayres Gear & Maintenance 0 10-11-2015 08:51 PM
Selling my 23K dthriftusa North American Yachts 0 03-11-2013 10:13 AM
The Spirit 28 kennya Boat Review and Purchase Forum 26 03-20-2012 12:02 PM
HTML code is Off
