Spirit 23 modifications - Page 3 - SailNet Community
 8Likes
post #21 of 51 Old 11-20-2012
Re: Spirit 23 modifications
I like this thread since I just bought a Spirit 23 this weekend but...
MORE PICTURES!
tschmidty is offline
post #22 of 51 Old 11-20-2012
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
MORE PICTURES!
Funny you should say this without posting a picture!
windyway is offline
post #23 of 51 Old 11-20-2012
Well I haven't modified my boat yet but it's only been 2 days! But here ya go, it needs some serious cleaning.
post #24 of 51 Old 11-21-2012
blobaugh's Avatar
tschmidty I like the instrument location! I may think about doing that. Though it may make in/egress to my vberth more difficult as the port side has a bulkhead across it
blobaugh is offline
post #25 of 51 Old 11-25-2012
I had a question for windyway who mounted the bilge pumps in front of the s/b trunk. How did you route the bilge hoses? Out the back to the bilge makes sense but the only question I have is whether there would be too much back flow when the pump stops from that long of a run.
post #26 of 51 Old 11-25-2012
no way could i read any of those instruments from the tiller without bino's
southern cross
ct-34
Southron Spirit is offline
post #27 of 51 Old 11-27-2012
windy way , if you get a chance i would like to see a better picture of the traveler set up ... also if you do the anchor set up please take lots of pictures .
tia
southern cross
ct-34
post #28 of 51 Old 11-27-2012
anybody put a roller furler on there jib ?
southern cross
ct-34
post #29 of 51 Old 11-27-2012
windyway's Avatar
I have 2 bilge electric pumps & 1 manual pickup under there. The electric pumps are routed on each of the settees on the inbrd corner tucked out of the way from the access hatches. They both go overbrd just behind the aft bulkhead & just under the bumper rubber port & stbrd sides. I made all the pumps have there own outlets cause I wanted to know which ones were working cause the second backup pump's pickup is higher than primary's one. The manual pickup goes to it's stock location out the back. If I have to use the manual pump with 2 electric pumps in there, back flow will be the least of my worries!
windyway is offline
post #30 of 51 Old 11-27-2012
windyway's Avatar
tia
What type of angles do you want specifically? If I do lots of pictures of the windlass install I'll put it under it's own thread.
windyway is offline
Sail modifications brokesailor Pacific Seacraft 0 03-06-2011 06:38 AM
Sailboat Modifications Tidewater General Discussion (sailing related) 15 08-16-2009 04:50 PM
Rudder modifications robbiebull MacGregor 1 05-07-2007 11:50 AM
Modern Modifications Dan Dickison Racing Articles 0 07-11-2001 08:00 PM
HTML code is Off
