The side stays on the deck were constantly angled the wrong way when either raising or lowering the mast. Consequently the "T" bolt kept getting bent. I was afraid that constant bending would eventually break it at the worst time...under load. I also didn't like the
turnbuckles that the boat came with. Also the sidestay
turnbuckles were too close to each other, so they were always interfering with each other when adjusting. So I decided to cut the old
turnbuckle off the cable & put 4 nicer ones in place. Since I didn't want to replace the whole cable (did I mention I'm economical?
) I bought some 1/4 316 stainless chain & used 3 links on each sidestay to lengthen the sidestays to make up for the cable I had to cut off. It also brought the
turnbuckles higher up on the
rigging so they don't interfere with each other anymore while adjusting, and having chain in place here prevents the
rigging from being angled the wrong way when moving the mast up or down, the chain just acts like a chain for 3 links!
This is called a "Chain Plate" isn't it??
