sink drain ? - Page 2 - SailNet Community
post #11 of 11 Old 12-10-2012
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
Re: sink drain ?
Those hull drains are EASY to replace, these boats are on a trailer right? I replaced mine & built up the inside pad cause the wood was all rotten when I got the boat. I have the thru hull still there but the valve is removed & the fitting is just capped off. When NA changed locations from the companionway to the strbd berth for the sink they didn't change the location of the fitting is my guess.
windyway is offline
How does a sink drain work? jarcher Gear & Maintenance 40 04-20-2016 09:23 AM
Macgregor / Venture 25 sink & ice box Drain Lines iamgres MacGregor 1 06-01-2010 05:18 PM
Plumbing sink drain to head intake CLucas Gear & Maintenance 12 03-08-2009 12:49 PM
Bilge Pump Exit - Why Not Use Sink Drain? montenido Gear & Maintenance 11 01-06-2009 12:16 AM
Parts for sink drain overholtzer S2 1 09-07-2007 04:07 PM
HTML code is Off
