Go Back   SailNet Community > Boat Builders Row > North American Yachts
  #1
Old 12-05-2011
Southron Spirit is on a distinguished road
sink drain ?
is the sink drain shut off valve on everyones boat on the bottom of the hull.
i was trying to figure out why there was a valve in the open positon with a hose on it ,traced it back to the sink .
the sink is to small to wash anything in anyway ,im going to use a rubber basin . i closed the valve and as soon as i can im going to remove the hose and screw a plug into that valve .
why didnt they just have it empty into the cockpit drain hoses
has anyone sealed that hole in the hull permanently ?
  #2
Old 12-05-2011
DRFerron's Avatar
The most female moderator
DRFerron is on a distinguished road
Are you referring to a galley sink or the sink in a head? The location of the valve will depend on the boat and if the previous owners made any modifications.
On our boat the galley sink drains directly out of the boat using a dedicated opening in the hull. There is a shut off valve located under the sink beneath the galley counter. Our sink in the head ties into the line that draws water into the head. If we close that seacock, the sink does not drain or any water in it will be drawn into the head when pumped.
I don't ever remember seeing a valve on the hull of a boat.
Donna
Catalina 30
Rock Hall, MD
Contributing Editor
magazine
SSCA Rock Hall Cruising Station
  #3
Old 12-05-2011
this valve comes out right next to the keel the other end leads to the sink where you are suppose to wash dishes but its so small you could probally only wash cups and silver ware . , the hose on the top left is for the swing keel cable.
  #4
Old 12-06-2011
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
On our boat every line that goes to a through hull, has a valve that can be closed...even through hulls above the water line. Our head sink drains above the water line, and the galley sink drains below the water line.
  #5
Old 12-06-2011
makenmend is on a distinguished road
On my NA 23' there is no such hull valve. Only through hull opening I have are 1. below waterline for speed sensor
2.cockpit drains above waterline.
  #6
Old 12-15-2011
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
windyway is on a distinguished road
My 79 has exactly the same hull fitting in the same place.
  #7
Old 12-16-2011
GoodOldBoater is on a distinguished road
I replaced my thru hull sink drain - same location as well.
1977 North American Spirit 23
  #8
Old 12-17-2011
JiffyLube's Avatar
Grasshopper
I've been thinking about our galley sink through hull, and wonder why it's below the water line. I'd think it would drain better above the water line.
  #9
Old 12-09-2012
Re: sink drain ?
every time i look at that thru hull below the water it gives me the willys .
i am going to look into pulling it out and filling the hole .
the first thing i have to do is figure out how to get in there under the cockpit .
S/V Erin Go Bragh
Spirit 23
  #10
Old 12-10-2012
Minnewaska will become famous soon enough
Re: sink drain ?
I would not remove the thru-hull, unless you don't ever want to sell the boat. The next owner may like to pour things down the drain, like most people do.
The location of the drain has to do with your hull shape and location of the sink. It needs to remain below the sink, even when heeled over. There should be a seacock, at the hull, for any thru hull that could be below the water when heeled over.
If the idea gives you the willies, then keep it closed when not in use. If you're concerned about it being rusted, then replace it.
Jeanneau 54DS
You may post attachments
You may edit your posts
Macgregor / Venture 25 sink & ice box Drain Lines iamgres MacGregor 1 06-01-2010 05:18 PM
How does a sink drain work? jarcher Gear & Maintenance 17 01-30-2010 08:24 PM
Plumbing sink drain to head intake CLucas Gear & Maintenance 12 03-08-2009 12:49 PM
Bilge Pump Exit - Why Not Use Sink Drain? montenido Gear & Maintenance 11 01-06-2009 12:16 AM
Parts for sink drain overholtzer S2 1 09-07-2007 04:07 PM
SEO by vBSEO 3.6.1
