Go Back   SailNet Community > Boat Builders Row > North American Yachts
  #1
Old 02-28-2012
Southron Spirit is on a distinguished road
changing bunk supports with spirit 23 still on trailer
the bunk supports on my trailer are in pretty bad shape .
i tried changing them out at the public boat ramp,was hard to work
with out power and all the traffic.
plus i was by myself and the boat kept getting blown off the center support rail before i could get it cranked in .
took me about 20 times before i got it so the swing keel was on the board.
any advice on how to jack up the hull enough to change one support at a time in my yard.
i have pavers ,cinderblocks ,boards , one railroad screw jack and several bottle jacks . would a 12"x12" piece of padded plywood work best or 4' secton of 2"x6" work better .
if i change them out at home ,i can take the lower section to work and beadblast them then cold galv them .
S/V Erin Go Bragh
Spirit 23
  #2
Old 03-02-2012
GoodOldBoater is on a distinguished road
I would drive trailer w/ boat to a local boatyard with a lift.
They are slow this time of year and could lift the boat off the trailer -
allow you access to power and replace your bunk supports (I'd replace then with rollers).
3000 lbs of boat hull is nothing to fool around with. Worth the $100 or so I think it would cost you to be safe.
D
1977 North American Spirit 23
  #3
Old 03-31-2012
Re: changing bunk supports with spirit 23 still on trailer
i had fully intended to follow your advice , but i went out and looked at the trailer and i guess on the return trip from the dock .
i lost the bolt out of the first piece that connects the support to the bunk .
the second support the whole piece was broken it was homemade out of
aluminum .
there was no way i could take it the 16 miles to the dock that way ,so i got a
long 4"x4" and put it across the trailer frame, got a bottle jack and another 2 ft 2"x4" to put on the hull .
as soon as i jacked it up enough i slid some surveying stakes under the keel
that way if something went wrong the boat would only move slightly .
jacked it up just enough to repace the bolt and the broken part .
now its at the club where i can take my time and do one at a time while the boat is in the water
i bought galvenised iron parts to replace all the homemade stuff
S/V Erin Go Bragh
Spirit 23
You may post attachments
You may edit your posts
Tartan 3700 extra bunk fbpetty Tartan 0 02-03-2012 08:53 AM
Flat-bed trailer & keel boat: cradle, supports or bunks? knotted Gear & Maintenance 32 03-05-2011 07:04 PM
Hans Christian 33T Bunk Measurments? snider General Discussion (sailing related) 2 01-01-2010 05:49 PM
A gripe! (under bunk access) deniseO30 Sailboat Design and Construction 16 11-23-2007 01:00 AM
SEO by vBSEO 3.6.1
