Go Back   SailNet Community > Boat Builders Row > North American Yachts
  #11
Old 01-07-2013
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
windyway is on a distinguished road
Re: Spirit 23 Swing Keel Cable Mod Dwg
Originally Posted by blobaugh View Post
Pull the hose off the center board slot,
What hose??
  #12
Old 03-11-2013
seas the day is on a distinguished road
I had the same problem last summer with my NA 23. I had the boat lifted, crawled under and replaced the broken cable. Now I suspect the keel is stuck in the recessed keel pocket.
Has anyone ever tried modifying a dagger-board instead of a swing keel? ?
  #13
Old 03-12-2013
windyway's Avatar
I guess you mean modifying from a swing keel to a dagger board? Other than the work involved, (major) why would you want to install a dagger board so it takes up valuable cabin space? The slot would have to extend beyond the water line. If you hit something with it, well there it goes... hope you would have reinforced the hull cause that may rip up too . Can a dagger board be made to swing as well? Oh yea, defeats the purpose.
I guess you could say I'm not too fond of the idea. But I'm a little confused here, if you had the swing keel out last summer, why would the keel be stuck now?
  #14
Old 03-12-2013
After a little more research I agree, a retro fit dagger board probably wouldn't be feasible. I guess I'm just not a fan of the swing keel design.. the cable to keel anchor point is too close to the pivot point, resulting in a great deal of tension needed to lift it. I like the pulley system idea, I may try that next.
I think it's stuck due to barnacle build up. The keel wouldn't lift when I tried loading her on the trailer in the fall. And of course the trailer winch broke! Had to use a come-along, which caused damage to the swing keel as she climbed onto the trailer. It's all part of the fun though!
  #15
Old 03-12-2013
windyway's Avatar
Swing keels are great...if the cable is routed correctly. I've always said this cable routing is the only poor design of this boat. I try not to take the quick fix approach to repairing boats, they will get you back, always! In your case in point, if you had of cleaned the barnacles off when the swing keel was out, you wouldn't have such problems now. It's just the way it goes. When I'm off of my main element (land) re: sea or air, I make damn sure ALL the mechanicals are 100% I don't want to be stuck on the water anytime. (in air your never stuck if you know what I mean! LOL)
  #16
Old 03-12-2013
SanCarlosSpirit is on a distinguished road
Re: Spirit 23 centerboard
I recently bought a spirit 23 and surprisingly everything seems to be in good repair and all of the parts are there (so far). However, I have not launched it yet. Can anyone tell me how the centerboard operates and what problems to antisipate?
Thanks
  #17
Old 03-12-2013
windyway's Avatar
Thanks
Can you post a new thread for this?
You may post attachments
You may edit your posts
Seafarer 24 swing keel, keel pivot? Sailing qualities? skygazer Boat Review and Purchase Forum 29 03-22-2012 07:45 AM
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Boat Review and Purchase Forum 52 03-07-2012 04:13 PM
Bilge Pump for 23ft swing keel American Spirit thomasward00 General Discussion (sailing related) 2 10-06-2011 04:24 AM
to Swing or Not to Swing ... keel that is nogin General Discussion (sailing related) 30 04-22-2010 09:57 AM
Swing Keel or Fixed Keel for Caribbean Sailing SailorJim123 Boat Review and Purchase Forum 1 02-04-2009 10:15 AM
SEO by vBSEO 3.6.1
