Spirit 6.5/23 Boom Vang/Jack - Page 2 - SailNet Community
post #11 of 13 Old 11-30-2012
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
Re: Spirit 6.5/23 Boom Vang/Jack
Originally Posted by jbcsailor View Post
... the closed top will keep the vang down and when you release the top, you can use the vang to hold the top up, at least till you can set slide stop.
I'm how can you release the top and still use the vang (fitting) to hold the top up??
windyway is offline
post #12 of 13 Old 11-30-2012
My thinking is that if both the vang and the top are attached to the slide then when the top is up you should be able to pull the vang to shorten it therefore not aloowing the slide to travel back down the mast. (Just a theory)
jbcsailor is offline
post #13 of 13 Old 12-01-2012
windyway's Avatar
I have a loop on the pop top front only. This attaches to the tang on the mast. The vang doesn't need to be hooked up cause the pop top pivots back to lower, it can't pivot back if it's tied to the mast, so it stays up regardless.
windyway is offline
Boom Vang vs Boom furling? Windkiller General Discussion (sailing related) 7 07-26-2011 07:27 PM
Boom Kicker Boom Vang dwottavian Gear & Maintenance 5 01-11-2010 12:48 PM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 10:33 PM
Boom Vang z1nonlyone Gear & Maintenance 5 08-21-2003 08:51 AM
Boom Vang sneuman General Discussion (sailing related) 6 03-14-2003 04:51 AM
HTML code is Off
