Windlass Installation - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 12-30-2012 Thread Starter
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
Windlass Installation Finally Done!
Well the windlass is finally done! A bigger job than I thought. Pictures below are from the finished work. Solenoids are placed beside the windlass motor in the FWD stowage upper port side. The 3" white pipe ended up to be at an angle of 11 deg & was 30" long under the FWD settee. You can see the rope exiting this pipe from the cockpit if the cover is left off this stowage area. The rope does not bind up in the pipe but does stop once the pile gets too high so I have to jump inside & scoop the pile AFT. But it works great to my relief
-Windlass Sol.jpg   -Windlass  Pipe1.JPG   -Windlass Pipe2.jpg   -WindlassCmplt.jpg
Southron Spirit likes this.
windyway is offline
post #12 of 16 Old 12-30-2012
Re: Windlass Installation
very cool , how about a picture of your anchor roller set up .
when its time to put windy way back on the trailer i would like to see
that also
southern cross
ct-34
Southron Spirit is offline
post #13 of 16 Old 12-31-2012 Thread Starter
windyway's Avatar
WindyWay is on the trailer now. She only comes off for sailing, keel work, & hull painting, & hopefully that's all behind me now (except sailing of course). The anchor roller is center on the bow, within a stainless attach bracket. It sticks over about 2 inches & has a loop of metal to keep the rode on it. The bow light is now mounted on the FWD pulpit. For 2 reasons, it's out of the way, and it can be seen farther away when the waves are high.
windyway is offline
post #14 of 16 Old 01-16-2013
what size chain are you using in your anchor rode and how long is the chain ?
southern cross
ct-34
post #15 of 16 Old 01-16-2013 Thread Starter
windyway's Avatar
I'm using a G40 5/16 chain & 5/8 rope cause the LEWMAR Concept 1 gypsy is a 002 & that is what the manual calls up. The chain is 20 ft long, rope 350 Ft. I know that is way overkill for a 23 footer but the gypsy has to have that size to work right. & there is tons of room under the V berth to accommodate it.
windyway is offline
post #16 of 16 Old 10-23-2013 Thread Starter
windyway's Avatar
Update: The rode makes it down the pipe OK but when the rope pile gets high below deck is when it bunches up. All I do is move the pile then all is well again.
windyway is offline
SSB Installation RadioTeck Electronics 169 01-01-2015 08:51 AM
Window Installation Strangersinponds General Discussion (sailing related) 3 12-23-2009 08:14 PM
AC Installation on PSC 31 mcgray Pacific Seacraft 16 07-28-2009 08:44 PM
VHF Antenna installation. engcon Gear & Maintenance 2 06-21-2007 08:53 PM
Electric Windlass Installation rclampitt Gear & Maintenance 10 05-08-2002 01:19 AM
HTML code is Off
