Blogs
Go Back   SailNet Community > General Interest Forums > Off Topic
User Name
Old 05-27-2008
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
What Makes a Good Opening Post
A good opening post should have a topic or subject line that describes what the thread will be about. It should also have a clear description of the question or problem that needs an answer. It should say what you have tried, if anything. It should provide the basic information that is necessary to solve the problem.
Here is a fairly good example of a good Opening Post from a recent thread, by a recent addition to our online community:
Subject Line:
The boat seems to be leaking water through the "tiller hole"...
The subject line says exactly what the problem is...
Body of Post
First off, the boat is a 1972 Bristol 26, swing keel version
Notice, he says right off what kind of boat it is, even which keel it has...
So on the way down the Hudson River from Kingston Sunday, we noticed that there was water leaking into the cockpit from the point where the "tiller base" (the part of the tiller assembly that is screwed to the floor of the cockpit) and the "spindle" (what I assume is a rod of some sort that is connected to the rudder).
We got the boat this spring (see "long island sound to hudson river cruise" thread) and are sure there has never been water leaking in before. We had a bungee cord wrapped around the tiller to keep the boat pointed in a steady direction, our "auto tiller"....and after we took the bungee off, the water stopped leaking a little while later. In total, there was about a half liter of water into the cockpit over the course of an hour or so.
He describes when he noticed the problem, and what the problem appears to be. He mentions that the problem is new, and references a previous thread of his... he'd get more points if he had actually linked to the thread in his post.
I did some investigative work, and there is a "tube" (what looks like a fiberglass pipe that looks like it is molded into the bottom of the hull) that goes from the cockpit straight down through the bottom of the boat. This is where my "rudder spindle" goes through. There was no water leaking in this area at all....in fact, it was dusty. Only several drops of water that I could tell were leaking in from above through the cockpit floor, where the "rudder spindle passes".
He says what he did to find out more about his problem.
My conclusion:
moderate to heavy pressure downward on the tiller puts pressure onto whatever gasket is inside the "tiller tube".
whatever gasket is in there is probably pretty old and should be replaced at the next convenience
And what he thinks the problem is...
My questions:
Worry about it now, or don't worry about it until this fall when we take the boat out....or if it gets worse before then, deal with it then
Can I deal with such a thing while the boat is in the water? I could see why totally disconnecting the assembly would probably mean my rudder would fall to the bottom.
It looks like my cockpit floor is above the waterline....maybe thats a given.
whaddya think, paranoid...or "another something to add to the list"
-Marty
Then he asks his questions...
Fairly clear, concise and with all the information you need to give appropriate advice.
Contrast that with the following post:
Subject Line:
Need a little advice
Subject line is a bit vague... isn't it....
Body of Post
I am planning a trip to the Upper Peninsula this summer. I am planning to take my newly purchased Cal 21. I am a novice sailor and feel a little intimidated to sail on lake Michigan but, REALLY want to sail while there. Can any one recommend an inland lake that would be a good one to try out?
Thanks.
Now the body of the post says his plans, and his fears...and asks a good question... but some information we need is missing. He doesn't say where he is located. Exactly how are we to suggest an inland lake for him to try out, if we don't know where he is? Overall, this isn't as bad as some opening posts...but if he said where he lived, it would be really easy to answer his question pretty well. From his UP reference, I could guess he is from Michigan, but he might have just gone to school there, and lives in Oklahoma...
Now here's a subject line that is a bit less vague...but could have been so much better:
Subject Line:
Boat Club Needed
Body of Post
Does anyone know of any good sailboat clubs in the Ft. Lauderdale area? My present income and lack of free time prevents me from purchasing my own boat. Right now I live in the D.C. area and there are several good sailing clubs around the region where, for a yearly fee, you can sail almost as much as you want. I am looking for these types of clubs around Ft. Lauderdale, where I will be moving in July. So far, my internet searches have been useless. Any Leads would be greatly appreciated.
Thanks
He says what his problem is, and what information he's looking for. In his first sentence he says Ft. Lauderdale. Would it have killed him to put Ft. Lauderdale in the Subject Line???
If you're looking for help... please, make it as easy as possible for people to help you. These two aren't even close to being winners for the worst opening post...
If you're new to the Sailnet Forums... please read this POST.
Old 05-27-2008
artbyjody's Avatar
artbyjody artbyjody is offline
artbyjody is just really niceartbyjody is just really niceartbyjody is just really niceartbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
And your point is?
A good reply to such post not properly composed is well the same stuff posted herel: please read this POST. as here... are we having a bad day SD?
-- Jody
S/V "Hello Gorgeous" - 1983, Barberis Show 38! or Facebook me.
Old 05-27-2008
teshannon's Avatar
teshannon teshannon is offline
teshannon has a spectacular aura aboutteshannon has a spectacular aura aboutteshannon has a spectacular aura about
I have absolutely no problem with an opening post that says "Hi. I'm new here". Most newbies don't have a question and just want to introduce themselves.
Sponsored Ad
Old 05-27-2008
Idiens's Avatar
Idiens Idiens is offline
Larus Marinus
Idiens is on a distinguished road
Where should I mount my solar stik?
Is it necessary to have a boat first? I have Ample hours to think about this.
Jonathan-Livingston
Old 05-27-2008
TrueBlue's Avatar
TrueBlue TrueBlue is offline
Seńor Member
TrueBlue is a jewel in the roughTrueBlue is a jewel in the roughTrueBlue is a jewel in the rough
With no disrespect to our high-post-endowed SD, since he does mean well.
But, I have to say that this thread seems a bit over the top. It's destined to be yet another hyper LINK, that newcomers to these forums will be instructed to adhere to. Or else, they will be chastised and sent to the bilges . . . at least until they learn how to use proper decorum.
True Blue . . .
sold the Nauticat
Old 05-27-2008
teshannon's Avatar
TB,
I agree. If I were a newbie I'd be intimidated and say the hell with it, I'm going somewhere else. Over time people pick up on most of what SD is saying and it all sorts itself out. It's not a big deal to me if you need to ask a follow up question now and then to see what a question is really about.
Old 05-27-2008
max-on's Avatar
max-on max-on is offline
1997 Dehler 33
max-on will become famous soon enough
There is a fine line between instructional and condescending.
Old 05-27-2008
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
camaraderie is a jewel in the roughcamaraderie is a jewel in the roughcamaraderie is a jewel in the rough
New Members Please Note
FOR ANY NEWBIES reading this thread. Please be aware that this topic is member SailingDogs' opinion and suggestion only. He is not a moderator or affiliated with Sailnet.
It is not the policy of this board to require or insist on anything other than that you follow the basic rules of decorum as outlined in the stickies at the top of the General Sailing Discussion forum. Obviously...if you have a question...the more details you can provide...the better the answers will be...But feel free to jump in anyway you choose.
www.anything-sailing.com
"Not too cold...not too hot...just right!"
Old 05-27-2008
Thanks Cam... I guess hanging out with the portagee was having some side effects...
Old 05-27-2008
Giulietta Giulietta is offline
Giulietta is just really niceGiulietta is just really niceGiulietta is just really niceGiulietta is just really niceGiulietta is just really nice
Ahh..now I get the blame for everything here too??
vB code is On
Wombat seeks your opinion on a possible new Womboat. tdw Boat Review and Purchase Forum 139 07-28-2008 04:14 AM
What makes a good family cruiser boat? tziehm herSailNet 16 08-04-2006 07:45 PM
Carbon Rudder Post Armchairprotest Gear & Maintenance 0 08-03-2004 11:28 AM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 08:00 PM
Ingredients for a Good Leader John Rousmaniere Her Sailnet Articles 0 08-27-2001 09:00 PM
Page generated in 0.8693 seconds (74.48% PHP - 25.52% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
