07-31-2008
Owner, Green Bay Packers
If you're using pvc to run the water line from the well to the house you're already making a mistake that will "keep on giving". Use 160psi black poly. The pvc is plenty strong enough but it will break, sooner or later, at one of the glue joints, usually right alongside the well. (I make a good living as a licensed well driller following around a certain driller who hooks his wells up with pvc.) The problem is that the ground settles and that places a stress on the pvc buried underground. The pvc pipe itself doesn't mind bending but every glue joint creates a hard spot that will crack when the ground settles. Sometimes it happens in the first year, sometimes down the road further. On the other hand, black poly doesn't care what the ground does afterwards.
I recommend a swing joint at the well casing also.
If you're using schedule 40 pvc you're also in big trouble. Use threaded schedule 80 down the well, assuming it is a pvc well of 5" diameter or larger, and use NO glue fittings within the well-thread and couple everything. If it is a 4" steel well you'd best be using steel drop pipe or you may not be able to pull the pump, some years later, without the pvc drop pipe breaking when the pump hangs up on mineral deposits and corrosion.
Note that schedule 40 pvc cannot be threaded, you need schedule 80.
Resist the foolish temptation to hang any pump down the well on black poly pipe. Just because it went in easy, doesn't mean it will come out the same way. Note also that breaking a pump off down the well may result in some bad events occurring, both of which will enrich a future well driller. It may take untold hours to "fish" the pump out of the well, if it's even possible. My experiences have varied from 5 minutes to 10 hours, at a rate somewhat north of $100/hr. If the pump cannot be fished, you'll have to drill a new well.
With no disrespect intended, I would offer that there is a reason that people hire me to do this job versus doing it themselves. (g)
Oh, btw, when that pvc breaks right next to the well casing, it's not uncommon for the leaking water to find it's path of least resistance up the conduit alongside the well. And the leaking water will carry sand and earth up with it and then down into the well, which will trash the pump or cause severe wear to it. So, in addition to having to repair a leak, you'll be buying a new pump to replace the old one that might not want to come up out of the well due to factors previously cited.
I don't think Murphy is hanging around you although I wouldn't be surprised that the master of the RMS Titanic is about! (g) Go ahead and PM me if you've any questions, before things get worse.
Wm. F. Buckley, Jr.
