Vagabond and Westwind Sailboats - SailNet Community
 8Likes
post #1 of 47 Old 03-02-2014 Thread Starter
Aquarian's Avatar
We (AJ and Cindy) have decided too start this thread as a means of documenting theses beautiful salty boats. We are currently in the process of restoring a 1981 Vagabond 42 (Gypsy). When we were researching these boats, we found very little info available, and a lot of questions posted around the internet by others with no replies/answers. We will be posting the results of our research as well as documenting Gypsy's restoration. Hopefully this will be of some help to others who hope to keep these beautiful boats afloat a bit longer. We welcome any questions, advice, and other helpful input that the community may offer. So, we begin.
Slayer and seafrontiersman like this.
Aquarian is offline
post #2 of 47 Old 03-02-2014 Thread Starter
Aquarian's Avatar
Re: Vagabond and Westwind Sailboats
Introducing Gypsy and a bit of background.
More before pix can be found here: https://www.dropbox.com/sh/c3b5033m6dlnn9h/upU3ZUUBSZ
Gypsy is a Vagabond 42. She and the Westwind 42 are the same I am told. I have never been on a Westwind. Both were designed by George Stadel III and built by Bluewater Yachts. They are members of the Leaky Teaky family.
Stadel also designed boats for Hans Christian, Shannon, and Mariner - a none to shabby collection of family members ;-).
VAGABOND 42 sailboat specifications and details on sailboatdata.com
This is a very solidly built boat with a thick hull, modified full keel, 9200 pounds of encapsulated iron ballast, and lots of teak. Our girl weighs in at 32,000 lb empty (according to the crane operator).
Gypsy will be my 3rd, and favorite, boat restoration. She has tons of character and a beautifully salty design.
Aquarian is offline
post #3 of 47 Old 03-02-2014
Aquarian
I've moved this thread to the Boat review section. Mods cannot create new forums, and there is no 'Vagabond' in the builders' row. I can put it into the 'other brands' category if you prefer.
Faster is online now
post #4 of 47 Old 03-02-2014 Thread Starter
Aquarian's Avatar
Hi Ron,
I think the Other Brands section of Builders Row might be best as we are not planning to review the boat, but rather document whatever info we can find and share pix and details about the restoration. Hopefully there are other owners who will contribute as well. We look forward to meeting them - or whatever you call it when you converse via a forum ;-)
Aquarian is offline
post #5 of 47 Old 03-02-2014
Originally Posted by Aquarian View Post
Hi Ron,
Done... carry on!
The Following User Says Thank You to Faster For This Useful Post:
Aquarian (03-02-2014)
post #6 of 47 Old 03-03-2014
Ilenart's Avatar
Hi Aquarian,
a few years ago I did a fair bit of reseach into Vagabond 42's so attached are some details I came across.
Ilenart
Ilenart is offline
The Following User Says Thank You to Ilenart For This Useful Post:
Aquarian (03-03-2014)
post #7 of 47 Old 03-03-2014 Thread Starter
Aquarian's Avatar
Thank you Ilenart. Every bit helps.
Aquarian is offline
post #8 of 47 Old 03-03-2014 Thread Starter
Aquarian's Avatar
Vagabond 42 FAQ - 1
What follows in the next few posts is some answers to some of the questions we've run across as well as a question or two of our own. This is not intended to be taken as any sort of absolute. We are sure there exists some variation, but this is what we have found so far.
1. Chainplates – Yes, they really are encapsulated in fiberglass on the hull interior. You might be able to view the layup of some of them inside of the aft deck locker (propane locker on our boat).
Yes, those rusty bolts are holding our chainplates in place - yikes!
Accessing the Chainplates is difficult. Some of them are behind lockers. Others are hidden by the beautiful teak paneling on the interior.
2. This paneling is strips of teak glued to 3/8” plywood that is screwed to firing strips fiberglassed to the hull. The teak must be removed to access the screws in the plywood which must be removed to access the chainplates. We will be addressing this issue in the near future with much creativity expected. Any suggestions are much appreciated. .
3. Interior teak appears to be finished with a very light lacquer coat. Lacquer cut by about 50% and applied with a cloth seems to work well for touching up warn areas or for sealing areas after sanding to remove water stains and whatnot.
4. The interior head liner is made up of removable FRP panels that provide very good access to deck fittings and wiring. So far we’ve not been able to locate a source for matching FRP should the need arise for replacement. If you know of a source, please share.
5. Gypsy had only 1 black water holding tank of unknown capacity. It was a bag in the bilge near the forward head. This bag was not anchored to anything – very creepy.
6. Gypsy’s showers drained into the bilge – yuck.
7. The anchor locker is large and drains into the bilge.
8. Decks – cored fiberglass with gelcoat top coat (under the teak). The coring appears to be plywood – we have not yet cut into it, but we will be as there is evidence of some moisture intrusion in a few places on deck.
9. Teak decking – does not appear to be structural. It is made of strips of teak butted together – no real gap at caulk seams. The seams are routed on one edge of each teak strip and do not go all the way through. The strips are laid in a bed of sealant on the deck and then screwed in place with a bajillion screws.
a. It appears the screw heads start showing when the teak has worn down to about 7/16”-3/8” thickness.
b. The caulk seams disappear when the teak reaches about ” of thickness remaining.
10. The bowsprit is mahogany
11. Engine – Ford Lehman model 2711E or 2712E, 80HP, parts for either are interchangeable.
a. Parts and service can be obtained from Bomac ( Bomac Marine- Ford Lehman Engines Parts, Remanufacture and Service )
b. Manuals are available from MarineEngine.com Ford Lehman Engine Manuals & Sabre Lehman Diesel Marine Engine Manuals
c. A free downloadable engine manual for a Ford Lehman 120 is available at: Owner's Manuals
d. I am told that removing the engine requires either disassembling it or cutting out the cockpit sole. The galley sink is above the engine and below the cockpit sole. So things could get messy.
e. Engine access is pretty good, but only from the sides.
f. Our water heater is located in the engine compartment.
12. Bilge structure and storage
a. Some of the supports located in the bilge are made of fiberglass encased plywood. In Gypsy’s case some of these have rotted, namely those supporting fuel and water tanks and one located under the forward bulkhead.
b. Fuel, water, and holding tanks are located in the bilge. There is very little remaining space for storage.
13. Fuel and Water tanks – Gypsy came to us with stainless steel fuel and water tanks. We have heard that these boats may have had iron/mild steel tanks originally, but have no experience with that. This definitely worth verifying as changing them out would likely require removing part of the cabin sole.
14. Water lines are copper and run through the bilge. The main water manifold is located inside the engine room behind the companionway steps. The valves appear to be brass – ours are corroded badly and will have to be replaced. It would be nice to relocate the manifold and create an access panel in that location for better access to the front of the engine if it is possible to do so without compromising the strength of the bulkhead.
15. Gypsy’s fridge has a couple of inches of added insulation on the interior of the fridge. This would imply that a PO thought the insulation was inadequate. We will be investigating this further.
16. ??? There is a mild steel beam corroding into rusty oblivion located under the aft berth. It is not clear if this beam is structural or not. The surveyor suggested that it was put in place to support the hull during construction and that it serves no present purpose except to incite speculation. If anyone knows, do please tell. Otherwise, research is ongoing.
Aquarian is offline
post #9 of 47 Old 03-09-2014 Thread Starter
Aquarian's Avatar
Some original sales brochures and specs for Vagabonds and Westwind 42 can be found here:
42 vagabond westwind 979
Thank you Florida Boats
Aquarian is offline
post #10 of 47 Old 08-02-2014
Thank you Aquarian! I noticed the post was four years ago so I was wondering how you made out with your Vagabond. I am considering pulling the trigger on a 1982 Vagabond 42 in Florida that comes with a deeded slip as a liveaboard. I don't know much about these boats and your post was very helpful. My first choice was a Hans Christian but I was afraid I would spend too much time on maintaining it so went looking at Vagabonds. I will be having it looked at by a pro in the area and I will be present. It is weathered outside and needs elbow grease inside. engine replaced in 2011 including trans and prop plus new fuel tank this year. It hasn't been under sail for a few months and has been sitting and lived on. Any info as to what and where to look other than what you have posted would be very helpful. I love these older classic boats and want to keep this one on the water where it belongs. Thanks and I hope you are enjoying yours.
caperss is offline
Westwind 42 vagabond Rippins Boat Reviews 22 05-07-2015 10:39 AM
Westwind Vagabond tgodlee Boat Review and Purchase Forum 3 05-30-2011 03:56 PM
vagabond westwind gto2 Cruising & Liveaboard Forum 0 01-04-2002 03:39 PM
vagabond westwind gto2 General Discussion (sailing related) 0 01-04-2002 03:24 PM
vagabond westwind gto2 Boat Review and Purchase Forum 0 12-26-2001 04:50 PM
