Yankee 26 - SailNet Community
 1Likes
  • 1 Post By Losantiville
post #1 of 9 Old 09-23-2016 Thread Starter
Yankee 26
First post here... so please take it easy on the new guy.
I'm going this weekend to look at a Yankee 26 that is for sale. It has been partially refit, but still needs a bit of work (currently engineless, needs bottom paint, maybe some other odds and ends, has been on the hard for several years). This isn't a question about whether this is a good boat for me - I already believe it is given my needs (will mostly just be me and my better half daysailing and weekend cruising) and my geography (PNW). There's just very little information out there on other Y26s. I know Yankee Yachts had a good reputation, I've read the forum posts where Yankee 26s have been mentioned, and I have raced against a Yankee 30 that always seems to do quite well against its PHRF rating. I have not found any testimonials of current or prior Y26 owners.
Is there anyone out there with specific experience / knowledge about these boats? Particularly, is there anything in particular I should be looking for when I go to see the boat?
Thanks in advance.
Losantiville is offline
post #2 of 9 Old 09-23-2016
Re: Yankee 26
Thanks in advance.
Not particular to the Yankee 26 but know the yankees are respectably built boats. I would look for more information concerning the Yankee 24 and the 30s because the manufacture of the boats are probably similar to get an overall idea of things to look for when surveying a boat from this manufacturer.
My one other suggestion in a boat of this class is compare a boat needing work and one in the best condition on the market. If the boat needing some TLC includes, engine, bottom paint, sails, and rigging and you can buy one fully upgraded for a few thousand more, spend the extra money on the better equipped boat.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #3 of 9 Old 09-23-2016
Lazerbrains's Avatar
Re: Yankee 26
I don't know much about the Y26, but am quite familiar with the Y30 and Y24. The Y26 was built during the same time frame as the Y30, so you want to check the deck core carefully. If it is built the same as the Y30, then they didn't seal the ends of the deck core - the one major flaw of an otherwise very well built boat. Often leads to soft spots on the deck, which are a big job to repair.
Lazerbrains is online now
post #4 of 9 Old 09-23-2016 Thread Starter
Re: Yankee 26
Thanks guys. Great advice about researching Y30s and Y24s to get a sense for general manufacturer issues from the era.
My understanding is that the current owner has already recored parts of the deck and sealed the joints with the hull. Will verify that to be the case.
Lazerbrains likes this.
post #5 of 9 Old 09-24-2016
Re: Yankee 26
That's promising information. I look forward to pics of the boat. I think the Y26 is a fairly uncommon boat.
post #6 of 9 Old 09-24-2016
Re: Yankee 26
Interesting.. must be one of the very first 'forward wrap-around settee/climb over into the V berth' layouts produced.
YANKEE 26 sailboat specifications and details on sailboatdata.com
The S&S pedigree is a good one, though as a 70s IOR type she may have some bad habits downwind. But good sail plan decisions can get around that.
The one thing that does give me pause is the engine/remote V drive arrangement. Wondering what engine access is like.. looks 'well squished aft'.... and with the pinched stern...
Faster is offline
post #7 of 9 Old 09-24-2016
Re: Yankee 26
Looks like a nifty weekender. Enjoy!
Sent from my Pixel C using Tapatalk
Bleemus is offline
post #8 of 9 Old 09-26-2016 Thread Starter
Re: Yankee 26
I went and looked at the Yankee 26 on Saturday. Overall, it was as promised. The current owner has spent years refitting the boat and the work he has done is beautiful. Completely rebuilt interior with cherry wood, deck re-cored, new teak toe rails, hand rails, companionway trim, all refinished stanchions and rails, new lights, topsides and deck painted.
There is, however, still a not-insignificant amount of work remaining to be done. As noted, it needs an engine (as well as a new diesel tank, prop, and controls), water tank / holding tank, galley stove and sink, v berth mattress, compass, vhf / nav, and in the not too distant future a set of sails as I think the ones it has now are the originals. I can wrap my head around all of that, however expensive it may be. What I'm struggling with is the bottom of the hull. It has been partially stripped / sanded by the current owner, though more needs to be done before barrier coat and bottom paint could be applied. As I was inspecting the hull, I noticed a couple of things that gave me pause. First is that there was a thru hull for the head that the current owner removed and began the process of glassing over. He acknowledged that he had just started to patch the hole and that there is more to be done, but I noticed from inside the boat that the current patch job is translucent and clearly quite thin. I also noticed while walking around the boat a thin crack maybe 18 inches long running from the very bottom of the boat vertically, then extending half again as far horizontally. This appeared to be a section that he had begun sanding but that still had barrier coat on it.
Any thoughts on this? Is patching an abandoned thru hull a big deal, and is it possible that crack is just in the barrier coat? Pictures attached for reference.
post #9 of 9 Old 09-26-2016
Re: Yankee 26
Patching an old through hull is not a big deal. As for the crack, looks like it is on the keel? If so, these are likely bolt-on lead keels and that shouldn't be a worrisome nor difficult crack to repair.
Yankee 30 NHM527 Boat Review and Purchase Forum 1 08-31-2016 11:56 AM
Yankee 38 Cal cruiser Boat Review and Purchase Forum 7 03-20-2016 06:17 PM
Yankee 30 L124C Other Brands 4 01-09-2016 07:15 PM
Yankee on a Crealock 37 brokesailor Pacific Seacraft 3 11-01-2014 04:32 PM
Yankee 30 msl Boat Review and Purchase Forum 3 06-10-2003 06:00 AM
